3756    <<    Message Index    >>    3758
Number: 3757
Date: Fri Oct 10, 2003  5:38 pm
Subject: Re: Underhood Light FIXED !!
That's exactly what I thought, too, Mike! Was probably "in" but not
snapped, and after 17 years it got loose & fell out.
First problem in 655 miles!! :)
> Excellent. Maybe it was never fully attached? Maybe it was
> overlooked at the factory? Most of the connectors snap so tightly
> that its almost impossible to get them separated without busting
them.
> > I fixed the underhood Light!
> > A coupling connection came apart.
> > At the lower edge of the hood, just inches above the firewall,
but
> > attached to the hood, is a coupling where the wire that goes up
> > the actual light and then comes down to connect to a small grey
> > plastic connector. It slides in to the other half and snaps
> locked.
> > That connection came apart, and the shorter wire (wrapped in
black
> > tape) had fallen down, outta sight, so I didn't see it. I
studied
> > the Silver 90 (which is at home) and that is where I saw that
> > connection, then I went down to the storage facility and looked
at
> > the blue '90 - only to see it was not there! So I went groping
> > around and found the "wire to nowhere" and saw the same plastic
> > connector and pick it up and snapped it in and VIOLA, the "bad"
> bulb
> > lit up!!
> > It's always good to have a spare identical car around to check &
> see
> > how something should be, on the real thing! :)
3758 Re: Underhood Light FIXED !! negusm negusm Fri  10/10/2003
3759 Re: Underhood Light FIXED !! Sandy Block cigarsandy Fri  10/10/2003
