3755
3757
Number: 3756
Date: Fri Oct 10, 2003 4:47 pm
Subject: Re: Underhood Light FIXED !!
Excellent. Maybe it was never fully attached? Maybe it was
overlooked at the factory? Most of the connectors snap so tightly
that its almost impossible to get them separated without busting them.
> I fixed the underhood Light!
> A coupling connection came apart.
> At the lower edge of the hood, just inches above the firewall, but
> attached to the hood, is a coupling where the wire that goes up to
> the actual light and then comes down to connect to a small grey
> plastic connector. It slides in to the other half and snaps
locked.
> That connection came apart, and the shorter wire (wrapped in black
> tape) had fallen down, outta sight, so I didn't see it. I studied
> the Silver 90 (which is at home) and that is where I saw that
> connection, then I went down to the storage facility and looked at
> the blue '90 - only to see it was not there! So I went groping
> around and found the "wire to nowhere" and saw the same plastic
> connector and pick it up and snapped it in and VIOLA, the "bad"
bulb
> lit up!!
> It's always good to have a spare identical car around to check &
see
> how something should be, on the real thing! :)
