3992    <<    Message Index    >>    3994
Number: 3993
Date: Fri Nov 21, 2003  9:28 pm
Subject: asc Coupe Parts
asc Coupe Parts
http://www.ascmclarencoupe.com/ascParts/
Check out this page...I have taken pics of alot of the correct parts
for the ascMcLaren Coupe.
The air horns are pictured there. I never had the original
compressor but the air horns survived and are in the first pic.
The next two pics showed an Anes air horn kit which is almost
identical (except for the compressor) to the ones found on the
coupe. The Anes compressor is nearly identical to correct one
except it does not have "Stebel Junior" stamped on it and it has a
yellow oil inlet.
http://www.ascmclarencoupe.com/Projects/AirHorns/compressors_top.jpg
The one on the right is the correct compressor.
3994 Re: asc Coupe Parts tfs2121 tfs2121 Sat  11/22/2003
3995 Re: asc Coupe Parts negusm negusm Sat  11/22/2003
3997 Re: asc Coupe Parts T D blklistd Sat  11/22/2003
3998 Re: asc Coupe Parts negusm negusm Sat  11/22/2003
4000 Re: asc Coupe Parts Sandy Block cigarsandy Sat  11/22/2003
