4050    <<    Message Index    >>    4052
Number: 4051
Date: Mon Dec 1, 2003  11:11 pm
Subject: Re: [ASC McLaren ] Digest Number 518
By the way, I took my ascMcLaren Coupe out yesterday for a 4 mile
ride. She goes good. I too noticed a small fuel smell, but it went
away. I think it was from laying dormant since August 3rd (last
allowed to go out date). I need air in 2 tires and gas, so it had
to go out. I took a look at the springs (spring conversation) I
could not count the turns. It needs to up on a lift to really be
able to see. If we could get a day that the forcast doesen't call
for "possible flurries" I'd take it for oil & filter change and get a
look see. Possibly next Monday, 12/8 ... I really should flush the
radiator - been 4 years since done.
-- In ascmclaren@yahoogroups.com, "Sandy Block" <cigarsandy@c...>
> My wife said they spoke this afternoon. She has an appointment at
a
> Mercury dealer for this Thursday. I'll let you know, as soon as I
> know. I've seen the car and it's probably one of the 20 nicest
> Capris left in the country. 1 small door ding, no scratchs,
perfect
> cloth seats, slightly worn rugs only on driver side (hi heels) ~
near
> mint condition. Dealer serviced and well care for. Garaged, no
> winters out and the Pop Up Sun Roof does NOT leak! PW PDL A/C
Speed
> & Tilt, bright red over charcoal lower, bottle cap opener wheels,
2nd
> set tires, am fm cassette, sun roof. Car is an automatic 5.0L.
> Never beat upon. Not 4-Sale, she really like it. "Fun Car" ~
> > I suppose that could happen to an injector. Please also know
that
> usually when they have problems is is due to the spray pattern into
> the engine getting messed up (due to and obstruction in the nozzle
or
> a crack) You can't see when this is happening. Usually you would
> also have a miss and the car would run like junk.
> > I still say it's the O2 sensor.
> > Can't hurt to replace anyway. If they are original they are
mighty
> tired anyway.
> > John
> > From: SNP Marq
> > To: ascmclaren@yahoogroups.com
> > Sent: Monday, December 01, 2003 8:38 PM
> > If it was a fuel injected 5.0 then I would suspect a faulty
> injector.... I had one 'go bad' and the smell of gasoline vapors
> was quite wicked.
> > And you can usually only spot it with the engine running. I
> forgot exactly what it is that 'goes' on them, but I think it was
> some kind of o ring. The fuel spurts out on to the engine
block...
> and evaporates rapidly because of the heat of the engine and
> manifold... so it leaves little evidence behind except the strong
> vapor smell. You need to have the engine running and a flashlight
> spot it while it is occuring... in order to zero in on which one
> fuel is spurting out of.
> > Marq
> > From: Sandy Block
> > Sent: Monday, December 01, 2003 8:18 PM
> > She says "Raw, unburnt gas" Like standing next to a gas pump
> taking
> > deep breaths as the fuel goes into the car....
> > S A N D Y
> > -- In ascmclaren@yahoogroups.com, Peter Shear <tfs2121@y...>
> > > is it a gas smell or is it like rotten eggs rotten egg
> > > smell is caused by the cat being cloged or a bad O2 if
> > > its a fuel thing it can still be the O2 and it sounds
> > > like it might be
> > > ~Peter
> > > __________________________________
> > > > > > Free Pop-Up Blocker - Get it now
> > > http://companion.yahoo.com/
4052 Re: Digest Number 518 negusm negusm Tue  12/2/2003
