4049
4051 Number: 4050 From: "Sandy Block" Date: Mon Dec 1, 2003 11:06 pm Subject: Re: [ASC McLaren ] Digest Number 518
My wife said they spoke this afternoon. She has an appointment at a Mercury dealer for this Thursday. I'll let you know, as soon as I know. I've seen the car and it's probably one of the 20 nicest Capris left in the country. 1 small door ding, no scratchs, perfect cloth seats, slightly worn rugs only on driver side (hi heels) ~ near mint condition. Dealer serviced and well care for. Garaged, no winters out and the Pop Up Sun Roof does NOT leak! PW PDL A/C Speed & Tilt, bright red over charcoal lower, bottle cap opener wheels, 2nd set tires, am fm cassette, sun roof. Car is an automatic 5.0L. Never beat upon. Not 4-Sale, she really like it. "Fun Car" ~
--- In ascmclaren@yahoogroups.com, John Gemelli <jgemelli@o...> wrote: > I suppose that could happen to an injector. Please also know that usually when they have problems is is due to the spray pattern into the engine getting messed up (due to and obstruction in the nozzle or a crack) You can't see when this is happening. Usually you would also have a miss and the car would run like junk. > > I still say it's the O2 sensor. > > Can't hurt to replace anyway. If they are original they are mighty tired anyway. > > John > ----- Original Message ----- > From: SNP Marq > To: ascmclaren@yahoogroups.com > Sent: Monday, December 01, 2003 8:38 PM > Subject: Re: [ASC McLaren ] Digest Number 518 > > > If it was a fuel injected 5.0 then I would suspect a faulty injector.... I had one 'go bad' and the smell of gasoline vapors was quite wicked. > > And you can usually only spot it with the engine running. I forgot exactly what it is that 'goes' on them, but I think it was some kind of o ring. The fuel spurts out on to the engine block... and evaporates rapidly because of the heat of the engine and manifold... so it leaves little evidence behind except the strong vapor smell. You need to have the engine running and a flashlight to spot it while it is occuring... in order to zero in on which one the fuel is spurting out of. > > Marq > > ----- Original Message ----- > From: Sandy Block > To: ascmclaren@yahoogroups.com > Sent: Monday, December 01, 2003 8:18 PM > Subject: Re: [ASC McLaren ] Digest Number 518 > > > She says "Raw, unburnt gas" Like standing next to a gas pump taking > deep breaths as the fuel goes into the car.... > > S A N D Y > > > > -- In ascmclaren@yahoogroups.com, Peter Shear <tfs2121@y...> wrote: > > is it a gas smell or is it like rotten eggs rotten egg > > smell is caused by the cat being cloged or a bad O2 if > > its a fuel thing it can still be the O2 and it sounds > > like it might be > > > > ~Peter > > > > __________________________________ > > > > Free Pop-Up Blocker - Get it now > > http://companion.yahoo.com/ > > > > > > > > > > > > > > > > > > > > > > >
