The answer to #s one & rwo are both ** YES ** Regarding the trunk, you are saying that the pull cable in the rear cove's "hidden compartment" is missing? If so, look in the glove box to see it there's a button in there. Lastly, disconnect the battery (one cable will do) and then re-connect. If a power trunk, it should then Pop Open. Good luck.
--- In ascmclaren@yahoogroups.com, "merstang85" <erndog02@e...> wrote: > Hi All > I am a new owner of a 85 McLaren Convertible. I found your site > while doing research on the car before buying it. I am glad to see > so many of these cars still live. I bought the red one off of ebay > that one of your member showed earlier. > This one is not in the best of shape. The sea breezes have been > blowing salt on it for too long. The rear fender extentions have > been the hardest hit( as in eaten through ) Also the tops of the > doors are starting to bubble under the paint. But the rest of the > body is solid and the engine rebuild he did about 80,000 miles ago > it still running strong. The interior is in need of a good going > over but he had recovered the recaro seats (comfy). > I have a few questions to ask if you don't mind. > `1. Will mustang doors fit if I change out the glass? > 2. Will a capri hood be a direct replacement? > 3. How do I get into the trunk? The silenoid just stopped working > and there is no cable in the manual release. I am kinda worried > about this one. > > Well I am off for a cruise any help will be appreciated. > Brian
