----- Original Message -----From: Sandy BlockSent: Sunday, January 25, 2004 12:26 PMSubject: [ASC McLaren ] Re: New Owner of a McLarenI keep mine disconnected all of the time. Botht the + and the -
However, I never use a tool. I have very slightly spread the "U"
things and just slip them over the terminals. They are quite secure,
but not "tight" ~ never have had any trouble.
The reason these cars go dead frequently without daily or semi-daily
running is because they have a hot-lead running all the time to the
top release motor. They is a constant draw. If taken to a dealer
and the do a search with a trouble light looking for ??? they will
ALWAYS tell you that you have a "short" because there is a constant
draw of current. Then they go messing up your car, for good. I have
connected & disconnected my convertible now for 13 years with
absolutely zero problems. I stop doing this in May, as then I run it
& drive it once a week, around the block, or a little bit further, to
the tune of 150 miles between May and October 1st per year, so 5
months divided by 150 miles or about 30 miles per month, May thru
September. Out once a week or like 7 miles per outing.
--- In ascmclaren@yahoogroups.com, Peter Shear <tfs2121@y...> wrote:
> always always always - first if you are takeing off +
> and you have your wrench on the nut and your wrench
> tuches the frame boom instintly you have just fused
> the wrench to the frame (the frame has negitive
> running through it "ground") my teacher once told me
> about this guy that was removeing the + b4 the - and
> he was whereing his wedding band and his band was
> tuching the wrench and then his band tuched the fame
> and it became fused to his finger and had to have it
> removed and he had 3rd degree burns where the ring
> was...
> shop safty!
> ~Peter
Yahoo! Groups Links
- To visit your group on the web, go to:
http://groups.yahoo.com/group/ascmclaren/
| Replies | Name/Email | Yahoo! ID | Date | ||
| 4376 | Re: New Owner of a McLaren | Sandy Block | cigarsandy | Sun 1/25/2004 |
