4375
4377
Number: 4376
Date: Sun Jan 25, 2004 6:40 pm
Subject: [ASC McLaren ] Re: New Owner of a McLaren
DON'T GO FINGER POKING OR PULLING IT APART, DICK.
-- In ascmclaren@yahoogroups.com, "Dick & Terrie" <rjohnson67@s...>
> Thank you Sandy and Peter for the battery infomation and
suggestions.
> Sandy, the info on the top-down/release situation is particularly
valuable to me. Thanks again!
> And, may I add - TO ALL OF YOU THAT PROVIDE VARIOUS TIDBITS ON THIS
WEBSITE - I certainly do appreciate that you take your time to
contribute.
> From: Sandy Block
> Sent: Sunday, January 25, 2004 12:26 PM
> I keep mine disconnected all of the time. Botht the + and the -
> However, I never use a tool. I have very slightly spread the "U"
> things and just slip them over the terminals. They are quite
secure,
> but not "tight" ~ never have had any trouble.
> The reason these cars go dead frequently without daily or semi-
daily
> running is because they have a hot-lead running all the time to
> top release motor. They is a constant draw. If taken to a
dealer
> and the do a search with a trouble light looking for ??? they
will
> ALWAYS tell you that you have a "short" because there is a
constant
> draw of current. Then they go messing up your car, for good. I
have
> connected & disconnected my convertible now for 13 years with
> absolutely zero problems. I stop doing this in May, as then I
run it
> & drive it once a week, around the block, or a little bit
further, to
> the tune of 150 miles between May and October 1st per year, so 5
> months divided by 150 miles or about 30 miles per month, May thru
> September. Out once a week or like 7 miles per outing.
--- In ascmclaren@yahoogroups.com, Peter Shear <tfs2121@y...>
> > always always always - first if you are takeing off +
> > and you have your wrench on the nut and your wrench
> > tuches the frame boom instintly you have just fused
> > the wrench to the frame (the frame has negitive
> > running through it "ground") my teacher once told me
> > about this guy that was removeing the + b4 the - and
> > he was whereing his wedding band and his band was
> > tuching the wrench and then his band tuched the fame
> > and it became fused to his finger and had to have it
> > removed and he had 3rd degree burns where the ring
> > was...
> > shop safty!
> > ~Peter
> > __________________________________
Groups Links
> a.. To visit your group on the web, go to:
> http://groups.yahoo.com/group/ascmclaren/
> b.. >
> c..
