4413    <<    Message Index    >>    4415
Number: 4414
Date: Wed Jan 28, 2004  7:22 pm
Subject: Re: About problem with opening the trunk.
not sure about this but i think i remember seeing a manual trunk
release in the gas door or am i thinking of the gas door release in
the trunk???? i know you had both in the rear compartments. maybe
your cable broke behind there??? take out the rear compartment and
investigate....
jdawg
jdawg
--- In ascmclaren@yahoogroups.com, "buick1933c"
<buick1933c@y...> wrote:
> This is for the person that had the problem opening his trunk.
There
> is an interlock swith mounted under the top cover. It is there to
> stop you from opening the trunk while you have the top cover up.
If
> the top cover doesnt go down far enough, the switch wont close.
Then
> the trunk wont open. You my need to adjust the hight of the top
> cover in order to close the switch. Hope this helps. Dan
