I was looking at Toms production pics. And he has a preproduction pic of a car with the door open and window up.
http://public.fotki.com/ascmclaren/ascmclaren_capris/ascmclaren_assemb ly/1987_pre_build.html
It appears that there is no frame around the door's window. So if this was taken before they attemped any modifications then I guess Ford shipped ttop/vert doors to asc attached to the car.
That may explain that black thing at the top of the window which probably kept the glass from rattling.
Now this begs another question...if guys were out walking the parking lot at Ford grabbing cars for an asc order...they would have had to swap doors before sending them to asc....and if they swapped doors, would they have to get the same color door?
Or am I crazy?
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > Sandy, did you find any info on your "homework" assignment on doors? > > If asc used Ford TTop/Vert doors for their conversion, what did they > do with the original doors that would have come on the car? > > Did asc get a truckload of TTop/Vert doors from Ford and when a car > came in, they removed the production doors, cut the top and refit a > set of TTop doors? > > Did Ford send a set of TTop doors along with each car? > > Did Ford put the TTop doors on the hatchback Capris and later on the > LX Mustangs before they were shipped to asc? That would make for > some odd fitting windows from the factory but would be the cheapest > solution. > > Just curious. > > -Mike > >
--- In ascmclaren@yahoogroups.com, "ecstacycustomz" > <ecstacycustomz@y...> wrote: > > look for a stang or capri with t-tops and power....no window frame, > > no cutting, just bolt on switch mouldings(maybe), windows, and > paint > > to match. > > jdawg > > > > > > > >
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > > > The doors on a 85 Mustang are the same as the Capri. The holes, > > > wiring, etc, should all the the same. On my car I had a Mustang > > > door swapped with the Capri door and there was no difference. > > Yes, > > > you need to move the glass and stuff over. > > > > > > Now, the doors on an 85 Mustang CONVERTIBLE may not be exactly > the > > > same. asc cut the window frame off the door when they did their > > > conversion. They may also have done a few other modifications. > > An > > > 85 GT convertible would have doors modified by Cars & Concepts > and > > I > > > doubt they cut the window frame off in the same way as asc. I > > THINK > > > they also added some door bumpers to keep the fit of the door > > tight > > > against the body so that flexing or warping would be minimized. > > > However, as I've never seen an asc vert door or a Mustang vert > > door, > > > a Mustang vert door may actually be less work if you find a good > > one. > > > > > > Some people at www.foureyedpride.com have taken > > hatchback/notchback > > > doors and converted them to vert doors by trying to follow what > CC > > > did. It was work but they have been successful. > > > > > > As always correct me if I'm wrong. > > > > > > -Mike > > > > > >
--- In ascmclaren@yahoogroups.com, "merstang85" <erndog02@e...> > > > wrote: > > > > Hi I was curious if anyone has tried to swap doors between a > > 85 > > > > Mclaren convert and a 85 GT stang. I know the windows would > need > > > to > > > > be exchanged and some trim. Are there any issues with the > wiring > > > > harness, both have power locks and windows. > > > > > > > > P.S. Sandy Only the cat.
