4421    <<    Message Index    >>    4423
Number: 4422
Date: Fri Jan 30, 2004  12:51 pm
Subject: Re: door swap
Re: door swap
You are correct. Ford built them at Dearborn WITH the T-Top doors,
thusly that big thick plastic thing attached to the top of the
window, to take up the space, during transportation & storage at asc.
When they switched to door mounted exterior mirrors in mid-1988, then
they switched to using the "convertible doors" which Ford HAD on
line. That is the same way the cars were recieved at C&C to be made
into Mustang Convertibles. Both Convertible & T-Top doors were the
same item, and were made by Ford at the Foundry Stamping Plant.
On another topic, I found some more "stuff" AMONG MY STUFF THAT
SPEAKS ABOUT 1991 changes. The only change was the addition of 16"
tires/wheels, as the regular Mustang of 1991 received. Now, it does
not tell WHAT wheel they were going to use. A search turned up that
the only 16" wheel they used in 1991 was for the Mark VII - however,
that wheel used a different off-set, and would not fit properly ona
1991 Mustang. There was no other FoMoCo car wheel to use, so it
woulda been interesting to know exactly WHAT wheel asc was intending
to use!! (Sadly, we'll never know). Perhaps they had not yet
figured it our, when the plug was pulled. No doubt something with
the same off set, by an aftermarket mfgr. Emkei might have even made
the same 89/90 wheel (Model 82) in a 16" with the correct off-set for
asc. Anyone know more ???
> I was looking at Toms production pics. And he has a preproduction
> pic of a car with the door open and window up.
http://public.fotki.com/ascmclaren/ascmclaren_capris/ascmclaren_assemb
> ly/1987_pre_build.html
> It appears that there is no frame around the door's window. So if
> this was taken before they attemped any modifications then I guess
> Ford shipped ttop/vert doors to asc attached to the car.
> That may explain that black thing at the top of the window which
> probably kept the glass from rattling.
> Now this begs another question...if guys were out walking the
parking
> lot at Ford grabbing cars for an asc order...they would have had to
> swap doors before sending them to asc....and if they swapped doors,
> would they have to get the same color door?
> Or am I crazy?
> > Sandy, did you find any info on your "homework" assignment on
doors?
> > If asc used Ford TTop/Vert doors for their conversion, what did
> they
> > do with the original doors that would have come on the car?
> > Did asc get a truckload of TTop/Vert doors from Ford and when a
car
> > came in, they removed the production doors, cut the top and refit
a
> > set of TTop doors?
> > Did Ford send a set of TTop doors along with each car?
> > Did Ford put the TTop doors on the hatchback Capris and later on
> > LX Mustangs before they were shipped to asc? That would make for
> > some odd fitting windows from the factory but would be the
cheapest
> > solution.
> > Just curious.
--- In ascmclaren@yahoogroups.com, "ecstacycustomz"
> > <ecstacycustomz@y...> wrote:
> > > look for a stang or capri with t-tops and power....no window
> frame,
> > > no cutting, just bolt on switch mouldings(maybe), windows, and
> > paint
> > > to match.
> > > jdawg
> > > > The doors on a 85 Mustang are the same as the Capri. The
> holes,
> > > > wiring, etc, should all the the same. On my car I had a
> Mustang
> > > > door swapped with the Capri door and there was no
difference.
> > > Yes,
> > > > you need to move the glass and stuff over.
> > > > Now, the doors on an 85 Mustang CONVERTIBLE may not be
exactly
> > > > same. asc cut the window frame off the door when they did
> their
> > > > conversion. They may also have done a few other
> modifications.
> > > An
> > > > 85 GT convertible would have doors modified by Cars &
Concepts
> > and
> > > I
> > > > doubt they cut the window frame off in the same way as asc.
> > > THINK
> > > > they also added some door bumpers to keep the fit of the door
> > > tight
> > > > against the body so that flexing or warping would be
> minimized.
> > > > However, as I've never seen an asc vert door or a Mustang
vert
> > > door,
> > > > a Mustang vert door may actually be less work if you find a
> good
> > > one.
> > > > Some people at www.foureyedpride.com have taken
> > > hatchback/notchback
> > > > doors and converted them to vert doors by trying to follow
what
> > CC
> > > > did. It was work but they have been successful.
> > > > As always correct me if I'm wrong.
> > > > -Mike
--- In ascmclaren@yahoogroups.com, "merstang85"
<erndog02@e...>
> > > > wrote:
> > > > > Hi I was curious if anyone has tried to swap doors
between
> a
> > > 85
> > > > > Mclaren convert and a 85 GT stang. I know the windows would
> > need
> > > > to
> > > > > be exchanged and some trim. Are there any issues with the
> > wiring
> > > > > harness, both have power locks and windows.
> > > > > P.S. Sandy Only the cat.
