4478
4480
Number: 4479
Date: Thu Feb 12, 2004 12:52 pm
Subject: Re: [ASC McLaren ] Coupe Rocker Panel and rear Cover installation
Also, heat the sticky side with your hair dryer for X-tra bonding
ability.
> Mike, since you brought it up: My '88 McL has the side molding from
front fender to rear. This is put on with tape.
> How do I know? Fortunately, one piece came off and was laying on
the garage floor.
> So my two cents: Check to see that the molding is on firmly
attached. IF IT COMES OFF when you are trying to see if it is firmly
attached, get some double-sided tape (automotive - AUTOZONE; etc.)
and reattach on a warm day. And, thoroughly clean the painted under-
surface with alcohol as well as the to-be-attached surface.
> I do not know about the rocker panels.
> Dick
> From: negusm
> Sent: Thursday, February 12, 2004 9:50 AM
> Subject: [ASC McLaren ] Coupe Rocker Panel and rear Cover
installation
> How did these attach? They look like they just used screws on
either
> end and inside the door frame.
> Was there any adhesive used?
> For the rear valence, was it rivetted, screwed or glued on?
> thanks.
Groups Links
> a.. To visit your group on the web, go to:
> http://groups.yahoo.com/group/ascmclaren/
> b.. >
> c..
