4479    <<    Message Index    >>    4481
Number: 4480
Date: Thu Feb 12, 2004  3:28 pm
Subject: Re: [ASC McLaren ] Coupe Rocker Panel and rear Cover installation
Are you talking about the belt mouldings put on by Ford? Yeah I know
all about those. I have NOS ones to go on.
I was talking about the asc rocker covers and the rear valence that
goes under the bumper cover. They are screwed on but Peter mentioned
that there was also some adhesive holding them on too which I didn't
know about.
I just want to make sure since the body guy is fitting everything
right now.
> Mike, since you brought it up: My '88 McL has the side molding from
front fender to rear. This is put on with tape.
> How do I know? Fortunately, one piece came off and was laying on
the garage floor.
> So my two cents: Check to see that the molding is on firmly
attached. IF IT COMES OFF when you are trying to see if it is firmly
attached, get some double-sided tape (automotive - AUTOZONE; etc.)
and reattach on a warm day. And, thoroughly clean the painted under-
surface with alcohol as well as the to-be-attached surface.
> I do not know about the rocker panels.
> Dick
> From: negusm
> Sent: Thursday, February 12, 2004 9:50 AM
> Subject: [ASC McLaren ] Coupe Rocker Panel and rear Cover
installation
> How did these attach? They look like they just used screws on
either
> end and inside the door frame.
> Was there any adhesive used?
> For the rear valence, was it rivetted, screwed or glued on?
> thanks.
Groups Links
> a.. To visit your group on the web, go to:
> http://groups.yahoo.com/group/ascmclaren/
> b.. >
> c..
4483 Re: Coupe Rocker Panel and rear Cover installation Tom G speedracer815 Thu  2/12/2004
