4580    <<    Message Index    >>    4582
Number: 4581
Date: Mon Feb 23, 2004  9:21 pm
Subject: [ASC McLaren ] Re: Black out window gasket?
If you are SURE SURE SURE that that number is correct. I will tell
my body guy to use YOUR number.
> I have PPG # 33717 "Flat Gray" Listed under BLACKOUT COLORS.
> However, there is also a "Flat Black" with # 9381.
> On my can, there is a paint smear over the hand written number,
> it's very hard to read (faded & smeared.)
> What # you got ??
> > OK, thanks for the heads up. Whats the ditzler number for the
> > charcoal paint?
> > I have a number and want to verify that it's correct.
<cigarsandy@c...>
> > > Mike, the installation of the L shaped aluminum charcoal
colored
> > > frame that the plexiglas window slides into can be tricky. If
> > am
> > > not mistaken, the frame gets pop rivited in at 3 points.
> However,
> > it
> > > it is not set "just so" when you go to screw in the vertical
> > seperate
> > > piece that rides up & down the "B" pillar, your door's frame
(top
> > > corner) will strike it and NOT allow the door to close.
You'll
> > need
> > > extra sets of arms & hands to get it done correctly, and it's
> very
> > > tricky. The tolarances are millimeters, and the fit has to be
> > super
> > > tight to prevent water from entering and getting trapped. If
> > can
> > > recall they are 3/8th screws to fit thru the holes in the B-
> Pillar
> > > finishing piece. IF yours are NOT painted charcoal, ask,
because
> > I
> > > have the paint code # (DuPont Ditzler)
> > > S A N D Y
> > > > Hanks got it.
> > > > I ordered some. I didn't ask what he charges, I never do.
> > just
> > > > pay for sh!t at this point.
> > > > -Mike
> > > > > bah, yet ANOTHER part to buy :-)
> > > > > -Mike
> > > <cigarsandy@c...>
> > > > > wrote:
> > > > > > Click onto the link that Peter supplied, from J.C.
> > Whitney.
> > > > Look
> > > > > at
> > > > > > #3 (top row across).
> > > > > > I took mine apart years ago to clean the water spots off
> and
> > > > that
> > > > > is
> > > > > > what sat IN the aluminum frame, which itself is shaped
like
> > > > a "U"
> > > > > all
> > > > > > the way around. The purpose of it was clear to me, to
keep
> > > > > lexan
> > > > > > plastic black out window panel from rattling in the
> aluminum
> > > > track
> > > > > in
> > > > > > which it sits. The piece we are talkig of was "fuzzy"
like
> > > felt
> > > > > on
> > > > > > the inside of the "U" and rubbery on the outside of
the "U".
> > > > > > Hank might have some. I think he does!!
> > > > > > S A N D Y
--- In ascmclaren@yahoogroups.com, Peter Shear
> > <tfs2121@y...>
> > > > > wrote:
> > > > > > > i THINK this is what it is
http://www.jcwhitney.com/webapp/wcs/stores/servlet/ProductDisplay?
> > > > > > makeId=1000130&productId=3258&catalogId=10101&langId=-
> > > > > > 1&modelId=1001513&storeId=10101
> > > > > > > ill try sending you a pic
> > > > > > > __________________________________
> > > > > > > > > > > > > Mail SpamGuard - Read only the mail you want.
> > > > > > > http://antispam.yahoo.com/tools
4582 Re: Black out window gasket? Peter Shear tfs2121 Mon  2/23/2004
4583 Re: Black out window gasket? negusm negusm Mon  2/23/2004
4584 Re: Black out window gasket? Sandy Block cigarsandy Mon  2/23/2004
4585 Re: Black out window gasket? Sandy Block cigarsandy Mon  2/23/2004
4586 Re: Black out window gasket? negusm negusm Tue  2/24/2004
4587 Re: Black out window gasket? Sandy Block cigarsandy Tue  2/24/2004
4588 Re: Black out window gasket? negusm negusm Tue  2/24/2004
4624 Re: Black out window gasket? negusm negusm Tue  3/2/2004
4628 Re: Black out window gasket? Sandy Block cigarsandy Tue  3/2/2004
