MIKE, any chance you could get a better shot of your build tag? I really cannot read it. A better pic & I could tell you most of it.
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > Yes, it would be nice if we could get some owners to post more of > their buck tags, door tags and any legible build sheets. > > My door tag as everyone probably has seen before is: > http://www.ascmclarencoupe.com/History/MasiBefore/door_tag.jpg > > My buck tag is here but I don't have the info on it: > http://www.ascmclarencoupe.com/ascParts/asc_BodyBuckTag.jpg > > Its in front of the radiator attached to the cross bar. > > -Mike > >
--- In ascmclaren@yahoogroups.com, "Tom S." <tkm654@c...> wrote: > > Again, the door tag DSO is different than the internal DSO code. > > The door tag DSO is for the District Sales office. This 2 digit > > code merely shows what district the car is/was intended for. For > > cars that were special orders there is an additional 4 digits that > > are undecipherible without internal paperwork. > > > > D32 is a code Ford used internally at the plant to identify a > > McLaren build. > > > > IF everybody would offer up their door tag info we could try to > > narrow down what codes are common for these cars and use those > also > > as identifiers. For instance, maybe all McLaren Capri coupes had > > the same DSO or maybe they all used the same spring codes which is > > coded with the transmission on the tag or maybe they all have the > > same Accesory Reserve Load codes that is printed above the DSO on > > the door tag. This could be done for the Coupes, Capri verts and > > the Mustangs also. There is nothing except the VIN on this tag to > > identify the car so a picture or two of the tag, with only the > last > > 6 digits of the vin blocked out if you so choose, would be great. > > If Sandy wants to handle the load of pics or if Negusm wants to > > fine, or I can too. A few examples of the tags: > > http://www.sspmustang.org/technical/doortags.htm > > > > Tom S. > > > > > > > >
--- In ascmclaren@yahoogroups.com, Peter Shear <tfs2121@y...> > wrote: > > > what about the door tag would it say anything about > > > the D32 build code or something? > > > > > > ~Peter > > > > > > __________________________________ > > > > > Search - Find what you're looking for faster > > > http://search.yahoo.com
