Ok, I have been looking into the buck tag code "HB" some more and it got me thinking. I dug out my "History 999" report out for my 1985 Cougar XR-7 and they list one the options as "Heated Backlight", aka..rear defrost. Today a rear defrosting window is pretty much standard equipment in probably any new car, but back when our cars were built it was an option, (required option in a couple of states). Since FLM officially named this a Heated Backlight, and being a major exterior building block of the car I do believe that this is what the "HB" stands for on the tag.
This is of course my own opinion and I still have no real proof of this so I'll just say it's still circumstantial evidence for my case. :-)
Brent
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > I wonder if HB could stand for High Back seats... > >
--- In ascmclaren@yahoogroups.com, "Brent Abrams" <babrams@l...> > wrote: > > I hit the send button too fast, so I'll start again. > > > > I always assumed that HB is for HatchBack, but after some looking > that > > doesn't make sense because that is what the "61D" means. > > This "HB" code appears in the same location on a Mustang buck tag > and the > > Mustang GT Registry also does not know what that code means but > their > > suspicion is that it possibly could be a rear defroster code. > > > > Thanks for the info on my car Sandy, I had gotten most of it from > you back > > when I found the car sitting on a used car lot and called you to > confirm > > what it was before I bought it. What I didn't have were the > recieving & > > shipping dates or the production line figures of how many Capri's > were built > > after mine, that's some pretty neat info. > > > > Brent > > > > > > > > > > > > > > ----- Original Message ----- > > From: "Brent Abrams" <babrams@l...> > > To: <ascmclaren@yahoogroups.com> > > Sent: Wednesday, March 10, 2004 2:24 PM > > Subject: Re: [ASC McLaren ] Re: Interesting figures > > > > > > I always assumed that HB is for HatchBack. > > > > ----- Original Message ----- > > From: "Sandy Block" <cigarsandy@c...> > > To: <ascmclaren@yahoogroups.com> > > Sent: Wednesday, March 10, 2004 2:13 PM > > Subject: [ASC McLaren ] Re: Interesting figures > > > > > > > Obviously I messed up! The HB is NOT the build date! Could not > have > > > been built in August & received in July! The HB is NOT the build > > > date. I don't know what it stands for. The McLaren dates of > > > receiving & shipping are indeed correct. > > > > > > SORRY > > > > > > > > > > > >
--- In ascmclaren@yahoogroups.com, "Sandy Block" > <cigarsandy@c...> > > > wrote: > > > > 618892 is a EuroCoupe, Oxford White. Received AT ascMcLaren on > July > > > > 15th 1986 & shipped out on July 24th 1986. It's the 13th of > the 47 > > > > EuroCoupes. They made 34 after it. It's one of 14 in color. > > > > Regarding the Buck-Tag:- > > > > 618892 is of course your sequence VIN. 61D is the code for a > Capri > > > 3- > > > > Door Hatchback. The "M" is the code for the 302 Cu In V-8 > with EFI. > > > > 9L is the code for Oxford White, while the PW is Power > Windows. > > > > > > > > The HB is the build date of August 2nd H=Aug B=2 They built > 1,977 > > > > 1986 Capris AFTER yours. > > > > > > > > Mustang took 93% of the build and Capri took 7% of the Dearborn > > > 1986 > > > > model year build, which was 245,279, or 20,869 Capri & 224,410 > > > > Mustang. > > > > > > > > S A N D Y > > > > > > > > > > > > > > > > > > > >
--- In ascmclaren@yahoogroups.com, "Brent Abrams" > <babrams@l...> > > > > wrote: > > > > > I don't have my door tag info handy but my body buck tag > reads as > > > > follows: > > > > > > > > > > CAPRI > > > > > 618892 61D M 0127 > > > > > > > > > 9L DF ST > > > > > AC 06 HB > > > > > PW 02 > > > > > A EI 06 2 X 2 NLR > > > > > > > > > > And of course the other smaller tag next to it that reads: > > > > > > > > > > MCLAREN COUPE > > > > > MCLAREN COUPE > > > > > MCLAREN COUPE > > > > > > > > > > Brent > > > > > 1986 EuroCoupe, White, Automatic > > > > > > > > > > > > > > > ----- Original Message ----- > > > > > From: "negusm" <negusm@y...> > > > > > To: <ascmclaren@yahoogroups.com> > > > > > Sent: Wednesday, March 10, 2004 10:59 AM > > > > > Subject: [ASC McLaren ] Re: Interesting figures > > > > > > > > > > > > > > > > Yes, it would be nice if we could get some owners to post > more > > > of > > > > > > their buck tags, door tags and any legible build sheets. > > > > > > > > > > > > My door tag as everyone probably has seen before is: > > > > > > > http://www.ascmclarencoupe.com/History/MasiBefore/door_tag.jpg > > > > > > > > > > > > My buck tag is here but I don't have the info on it: > > > > > > http://www.ascmclarencoupe.com/ascParts/asc_BodyBuckTag.jpg > > > > > > > > > > > > Its in front of the radiator attached to the cross bar. > > > > > > > > > > > > -Mike > > > > > > > > > > > >
--- In ascmclaren@yahoogroups.com, "Tom S." <tkm654@c...> > wrote: > > > > > > > Again, the door tag DSO is different than the internal > DSO > > > > code. > > > > > > > The door tag DSO is for the District Sales office. This > 2 > > > > digit > > > > > > > code merely shows what district the car is/was intended > for. > > > > For > > > > > > > cars that were special orders there is an additional 4 > digits > > > > that > > > > > > > are undecipherible without internal paperwork. > > > > > > > > > > > > > > D32 is a code Ford used internally at the plant to > identify a > > > > > > > McLaren build. > > > > > > > > > > > > > > IF everybody would offer up their door tag info we could > try > > > to > > > > > > > narrow down what codes are common for these cars and use > > > those > > > > > > also > > > > > > > as identifiers. For instance, maybe all McLaren Capri > coupes > > > > had > > > > > > > the same DSO or maybe they all used the same spring codes > > > which > > > > is > > > > > > > coded with the transmission on the tag or maybe they all > have > > > > the > > > > > > > same Accesory Reserve Load codes that is printed above > the > > > DSO > > > > on > > > > > > > the door tag. This could be done for the Coupes, Capri > verts > > > > and > > > > > > > the Mustangs also. There is nothing except the VIN on > this > > > tag > > > > to > > > > > > > identify the car so a picture or two of the tag, with > only > > > the > > > > > > last > > > > > > > 6 digits of the vin blocked out if you so choose, would > be > > > > great. > > > > > > > If Sandy wants to handle the load of pics or if Negusm > wants > > > to > > > > > > > fine, or I can too. A few examples of the tags: > > > > > > > http://www.sspmustang.org/technical/doortags.htm > > > > > > > > > > > > > > Tom S. > > > > > > > > > > > > > > > > > > > > > > > > > > > >
