4801    <<    Message Index    >>    4803
Number: 4802
Date: Mon Mar 22, 2004  10:01 am
Subject: Re: [ASC McLaren ] Paint (was: '84 hood scoop pics now available)
> BTW, you are absolutely correct about the basecoat not
> holding up well without the clear. (I wonder if that's
> where some of the myths concerning clearcoat come
> from.) It also will not have the proper finish (or
> "sheen"), it is meant only as a base for the clear.
> Since that color is non-metallic I can't imagine why
> they would refuse to use single coat paint on it.
Yeah, I will mention it. That is probably part of the confusion.
They are thinking to paint it in a basecoat lacquer and I need to
see if they'll do enamel or whatever it was from the Factory.
Do you know what type of paint (enamel or lacquer) that the factory
did the trim with?
Do they make a non basecoat/clearcoat lacquer based paint?
4803 Re: Paint (was: '84 hood scoop pics now available) Tom G speedracer815 Mon  3/22/2004
