4805    <<    Message Index    >>    4807
Number: 4806
Date: Mon Mar 22, 2004  3:42 pm
Subject: Re: Door Frame Piant >> MIKE !!
Thanks so much Sandy! I will relay the info!
Now I have another question. Being that that says it is a "flat
grey". What is the correct sheen on the pillars/door frame/roof
line? Is it supposed to be flat? Or is that are supposed to be
glossy while the exterior mouldings like around the windshield or
hatch or sail panel supposed to be flat?
I was looking at a few cars and the area around the window frame on
the door which whould be dark charcoal looks about like the same
sheen as the rest of the car which is glossy.
I'm afraid that if I have the trim painted with no clear coat, the
unibody area around the door's window is going to look odd against
the basecoat/clearcoat blue.
> Mike, and everyone, I opened my fresh can of paint, and dabbed an
> area this size: OO with it, on the ascMcLaren-installed
> verttical "B" pillar finishing moulding. THAT'S the piece you
> install, AFTER you slide in the black-out plexiglass window over
> side rear quarter stock windows. It's a vertical finishing
aluminum
> moulding that runs from the top of the door frame, to the bottom,
or
> top of the side door panel. It covers the opening between the
glass
> FoMoCo rear quarter window & the ascMcLaren installed black-out
> plexiglass window, when viewed with the door OPEN, looking between
> the 2 windows. Got it?
> Okay, I ordered PPG paint code 33717 Dark Charcoal for t-
Bird/Cougar
> according to the chart. It seems a bit too dark, but when it
dried,
> it was a near perfect match. The very tip top 90-degree point of
my
> driver's door frame ever-so-slightly skims this aluminum moulding
at
> the very top of the moulding. It hardly touches it, but every 2
> years or so, I need to dab it, as it's wrom off. I tried
tightening
> the 3 screws in that piece, but they are as tight as they can go.
> The tolerance just isn't there. The passenger's side does not
touch.
> It has been that way since day-1 - back on November 2nd 1986 when
> found my love at Wayne Lincoln-Mercury in Wayne, New Jersey.
> Here's the chart I used:
> http://autocolorlibrary.com/cgi-bin/search/searchpic.pl?1986-ford-
> Best of luck. BTW....It was $35.00 for a pint.
4807 Re: Door Frame Piant >> MIKE !! Sandy Block cigarsandy Mon  3/22/2004
5020 Re: Door Frame Piant >> MIKE !! negusm negusm Thu  5/13/2004
5021 '84-'86 Fog Light Question Tom G speedracer815 Fri  5/14/2004
5022 Re: '84-'86 Fog Light Question Sandy Block cigarsandy Fri  5/14/2004
5023 Re: '84-'86 Fog Light Question negusm negusm Fri  5/14/2004
5025 Re: '84-'86 Fog Light Question ascmclarencoupe ascmclarencoupe Sat  5/15/2004
5026 Re: '84-'86 Fog Light Question Sandy Block cigarsandy Sat  5/15/2004
5040 Re: '84-'86 Fog Light Question negusm negusm Mon  5/17/2004
5054 Photo Section Tom G speedracer815 Sun  5/23/2004
