4960    <<    Message Index    >>    4962
Number: 4961
Date: Thu Apr 22, 2004  2:36 pm
Subject: Re: [ASC McLaren ] Under Hood Insulator Pad
Mostly resolved. I think the pad I got may have been cut for a 4cyl
car or the early pads were longer. Everyone with an 85-86 Capri
with either a V6 or V8 says that it only goes to the tabs. So I
just have to cut the pad down. No biggie.
However, if you have some pics of the pad and the cutouts envolved
(for the sticker, underhood light, etc) I would be very appreciative
since I would like to make the correct holes in the new pad. The
hole for the underhood light is a bit messed up on the original pad
I have and I'd like a picture of that area if you have one.
Thanks.
> Mike,
> Did you get this resolved?
> I went through my Capri picture album and found a couple of
pictures of the
> pad that may answer your questions.
> If you need them I can get them scanned and send them to you.
> Brent
> Sent: Monday, April 19, 2004 11:46 AM
> Subject: [ASC McLaren ] Under Hood Insulator Pad
> In my never ending quest to replace the underhood insulator on my
> car, I got a repro underhood insulator off from ebay.
> Here is the thread that I started at www.foureyedpride.com:
> http://www.foureyedpride.com/phpBB2/viewtopic.php?p=49623#49623
> Long story short, does anyone know if the 84-86 Capri pads go as
far
> as the tabs near the front of the hood or do they extend farther
> front and have clips that clip them to the underside?
> More importantly, does anyone have the original underhood pad on
> their Capri? Could they take some pictures? I'd also be
interested
> is seeing the openings in the pad so that I can cut the correct
> holes for the light and sticker as well as anything else that is
> missing.
> Sandy, maybe if you happen to visit your coupe, you could take some
> shots of it. I'm sure its like new there :-)
Groups Links
