5234    <<    Message Index    >>    5236
Number: 5235
Date: Wed Jul 14, 2004  8:45 am
Subject: Re: 85-86 Dark Charcoal Trim Codes
Therefore, I have found that the only two vehicles that I cannot
compete with for attention are a Ferrari and a snack wagon !
> Mike, I don't know. What do you think. Look directly above this
> message, to the left slightly and you'll see in BOLD black the
> word "Messages" ~ now, look at the size of the area of the "e" in
> that word. THAT is the size of the area that I touch up. I do it
> about once every 3 years. It's on the "B" pillar cap, the vertical
> aluminum piece (asc supplied) that is on the "B" pillar. The very
> tip top edge of my door frame very slightly (millimeters here)
> touches the very top of that vertical aluminum cover bar when
> opening/closing the door. It wears of the paint in an area the
size
> of that "e" in the above word "Messages" ~ I have a brand new,
never
> opened, pint of 33717. I think it was pretty expensive, at $37.50.
> I apply it using a paper (torn from book) match (bottom of match)
> using like a single small dab, and then feathering it out to cover
> the small area. It dries pretty fast and is barely noticeable.
> I had to buy a new battery a few weeks ago for the car. The OEM
> battery has been discontinued. The replacement battery just fits
in
> the battery trey but a hair ! It's a bit bigger (stronger) battery
> than the OEM. It is (of course) a Ford battery $82.50.
> It was a funny scene. I actually drove her the 2 miles to the
dealer
> & parked her in the Customer Parking in front of the showroom. I
> left the car & went into the service Dept. to locate the Parts
Dept.
> As I glanced back at her, the showroom had emptied and there were 7
> guys standing around her looking & pointing and talking. The front
> lot was very visiable from where I stood at parts counter. Others
> came out to look, I think from the front office. Soon there were 9
> people standing 'round my Mac. Then, the snack-wagon pulled in and
> as if my car turned to a ticking bomb, all 9 immediatley forgot my
> car existed, and went like magnets to the snack-wagon! It was
funny
> to watch. Nice car, WOW what IS it? Yada, Yada, Yada, HEY -
SNACK
> WAGON ... GOODBYE CAR
> > I probably will eventually. I want to see the pics of this stuff
> > when this guy gets his car painted here this week.
> > Problem is, I don't know how much better it will be for "touch
up"
> > work.
> > Dabbing the 33717 paint that you already have onto your small
area
> > on the driver's side trim probably produces a satin-like effect
> > anyways.
> > If you take "satin" (or flat) spray paint and brush it on a
> surface,
> > it will be more glossy than if you spray it on. If you spray a
> > satin paint on EXTREMELY THICK you can achieve a very glossy
> > appearance too. You can also take a GLOSSY paint and on a dry
day,
> > hold the can far away (so the paint starts drying in mid flight)
> and
> > achieve a Satin or "Matte" effect.
> > But sure, if I get some made up, I'll be glad to send you a
pint.
> I
> > don't know if you'll need to mix the reducer or dcx61 in before
> > touching up or not.
<cigarsandy@c...>
> > > WoooHooo
> > > Get some made up Mike and I'll buy a pint from you.
> > > S A N D Y
> > > > I finally found someone who looks like they have the right
> > formula
> > > > for the 85-86 Dark Charcoal trim!
> > > > A guy at FEP has a car being painted and the painter used to
> > > restore
> > > > Fox Mustangs and had a formula for getting the correct FINISH
> > for
> > > > the paint. The 33717 paint code IS the right color but if
> mixed
> > > > like normal (in a base coat) it comes out WAY too FLAT. Then
> > when
> > > > clear coated its WAY shiny. The following should mix a quart
> of
> > > > 33717 single stage paint that should be SATIN!
> > > > Here's the formula for 33717 single stage. its based
> > > > on a quart can of mixed color. the manufacture is PPG.
> > > > code color parts
> > > > dmc902 black 226.6
> > > > dmc900 str. whi 215.8
> > > > dmc901 str. bla 137.5
> > > > dmc929 lt red 76.0
> > > > dmc904 blue 38.5
> > > > dx995 matt bas 421.9
> > > > additional notes:
> > > > mix 6 pts paint - 2 pts dt reducer - 1 pt dcx61
> > > > special low gloss color
> > > > this is the correct color for all body side molding and trim
> for
> > > > 1986 mustang gt - charcoal.
> > > > -Mike
5236 Re: 85-86 Dark Charcoal Trim Codes negusm negusm Wed  7/14/2004
