5233
5235
Number: 5234
Date: Wed Jul 14, 2004 8:39 am
Subject: Re: 85-86 Dark Charcoal Trim Codes
Mike, I don't know. What do you think. Look directly above this
message, to the left slightly and you'll see in BOLD black the
word "Messages" ~ now, look at the size of the area of the "e" in
that word. THAT is the size of the area that I touch up. I do it
about once every 3 years. It's on the "B" pillar cap, the vertical
aluminum piece (asc supplied) that is on the "B" pillar. The very
tip top edge of my door frame very slightly (millimeters here)
touches the very top of that vertical aluminum cover bar when
opening/closing the door. It wears of the paint in an area the size
of that "e" in the above word "Messages" ~ I have a brand new, never
opened, pint of 33717. I think it was pretty expensive, at $37.50.
I apply it using a paper (torn from book) match (bottom of match)
using like a single small dab, and then feathering it out to cover
the small area. It dries pretty fast and is barely noticeable.
I had to buy a new battery a few weeks ago for the car. The OEM
battery has been discontinued. The replacement battery just fits in
the battery trey but a hair ! It's a bit bigger (stronger) battery
than the OEM. It is (of course) a Ford battery $82.50.
It was a funny scene. I actually drove her the 2 miles to the dealer
& parked her in the Customer Parking in front of the showroom. I
left the car & went into the service Dept. to locate the Parts Dept.
As I glanced back at her, the showroom had emptied and there were 7
guys standing around her looking & pointing and talking. The front
lot was very visiable from where I stood at parts counter. Others
came out to look, I think from the front office. Soon there were 9
people standing 'round my Mac. Then, the snack-wagon pulled in and
as if my car turned to a ticking bomb, all 9 immediatley forgot my
car existed, and went like magnets to the snack-wagon! It was funny
to watch. Nice car, WOW what IS it? Yada, Yada, Yada, HEY - SNACK
WAGON ... GOODBYE CAR
> I probably will eventually. I want to see the pics of this stuff
> when this guy gets his car painted here this week.
> Problem is, I don't know how much better it will be for "touch up"
> work.
> Dabbing the 33717 paint that you already have onto your small area
> on the driver's side trim probably produces a satin-like effect
> anyways.
> If you take "satin" (or flat) spray paint and brush it on a
surface,
> it will be more glossy than if you spray it on. If you spray a
> satin paint on EXTREMELY THICK you can achieve a very glossy
> appearance too. You can also take a GLOSSY paint and on a dry day,
> hold the can far away (so the paint starts drying in mid flight)
> achieve a Satin or "Matte" effect.
> But sure, if I get some made up, I'll be glad to send you a pint.
> don't know if you'll need to mix the reducer or dcx61 in before
> touching up or not.
> > WoooHooo
> > Get some made up Mike and I'll buy a pint from you.
> > S A N D Y
> > > I finally found someone who looks like they have the right
> formula
> > > for the 85-86 Dark Charcoal trim!
> > > A guy at FEP has a car being painted and the painter used to
> > restore
> > > Fox Mustangs and had a formula for getting the correct FINISH
> for
> > > the paint. The 33717 paint code IS the right color but if
mixed
> > > like normal (in a base coat) it comes out WAY too FLAT. Then
> when
> > > clear coated its WAY shiny. The following should mix a quart
of
> > > 33717 single stage paint that should be SATIN!
> > > Here's the formula for 33717 single stage. its based
> > > on a quart can of mixed color. the manufacture is PPG.
> > > code color parts
> > > dmc902 black 226.6
> > > dmc900 str. whi 215.8
> > > dmc901 str. bla 137.5
> > > dmc929 lt red 76.0
> > > dmc904 blue 38.5
> > > dx995 matt bas 421.9
> > > additional notes:
> > > mix 6 pts paint - 2 pts dt reducer - 1 pt dcx61
> > > special low gloss color
> > > this is the correct color for all body side molding and trim
for
> > > 1986 mustang gt - charcoal.
