New owner in Surprise Arizona
NEED HELP REGISTERING? LOGGING IN? CHECK HERE FOR HELP!
Tx Trooperstang wrote:Goodyear Gatorback Repops are available now if some of you don't know.
Tom
    Problem is that these were never used on our cars.
    At least for the Capris, they were lower profile tires and tough to find now.
    Tires
    Yes, they are available at $325 per tire. Wtf.
    While I put nos parts on my car, it's more of a daily driver. I have 3 car now with dried out side walls which will never get worn out. I dont see it as a good long term investment as are nos parts.
    Tires
    Double post
    Tx Trooperstang
    Post by Tx Trooperstang »
    I have a contact from the SSP Web site that they can be obtained cheaper. Less than $280.00 a tire.
    Tom
    Coming soon # 1079
    AZCruisen
    Post by AZCruisen »
    Well the 20's are off and the stock wheels back on, albeit missing the center caps. I went with the Falkens, and at $77 a tire they will work fine. Tread looks good on it actually, and they are the proper size. Can't wait to take it for a spin to see how much better it rides now compared to those 20's. Does anyone know if there is a comparable center cap that is cheap that I can throw on for now until I can justify the $180 for the proper ones?
    Hank, I will be taking it up there for sure now since I have the wheels on. We will be there probably around noon. Still have to clean it up tomorrow morning.
    Caps
    If you have the old center caps, someone made stickers. Which falkens did you get, 512 or 912?
    AZCruisen
    Post by AZCruisen »
    Here are a couple photos from when I loaded her up to bring it home.
    Pics
    Looks better than i thought it would. My pull down motor has not worked long before it got it. I just used the latch to release it and stick my fingers under it to release it. I think my relays are the problem but have not got around to troubleshoot.
    AZCruisen
    Post by AZCruisen »
    Tires are the 512. My pull down motor is busted in pieces. I am currently looking for a replacement from a caddy.
    Motor
    You can find replacement plastic housings on eBay.
    Tx Trooperstang
    There are a set of caps on Ebay.
    Tom
    Coming soon # 1079
    AZCruisen
    Post by AZCruisen »
    Thanks for the tip on the caps. Hope to get those! Cleaned up the car today. Man did it need it. Took her up to the Pavillons cruise in Scottsdale and had a blast.
    [/img]
    Tx Trooperstang
    I learned something new about the tire sizes used. Coupe used 225 50 15 and Convertibles used 215 65 15 in 85'.
    Tom
    Coming soon # 1079
    hanksgt
    Post by hanksgt »
    Car looks great. So glad you're out cruising with it already. Don't forget the pizza cruise Sat Jan 27!
    AZCruisen wrote:Thanks for the tip on the caps. Hope to get those! Cleaned up the car today. Man did it need it. Took her up to the Pavillons cruise in Scottsdale and had a blast.
    [/img]
    Hank
    Phoenix
    '89 ASC #176
    '87 ASC #134
    '85 GT
    Tires
    Pretty sure the vert. Used 225/60-15 tires
