0636
0638
Number: 0637
Date: Sat Mar 9, 2002 2:58 pm
Subject: Re: 88 McLaren
This rear axle ratio is a "grey area". I do know that the 2.73:1 was
standard equipment in the 5-Speeds, and that ALL cars with a D32 code
(asc/McLaren Spec) that were 5-Speeds did get the 3.08:1 ratio. NOW,
according to asc/McLaren paperwork dated 1/'87 it states that
the "normal" rear axle ratio for an automatic 5.0L LX or GT was a
3.23:1. It further states that D32 Spec Automatics would receive AT
FORD the FORD AXLE RATIO of 3.72. Is it possible that this didn't
REALLY take place? Yes, I guess so. Did it take place on SOME cars
and NOT OTHERS? Possible! Was it 1987s only? MAYBE!? Was it
planned, and not done? MAYBE. Perhaps yours was among SOME that did
not receive it?? Possibly!! I am not, never was mechanical, so I
have never taken one apart as you have, and if I did, I would not
know what I was looking at, anyhow......so, I sure as heck I'm NOT
doubting your intelligence, as I am sure you are correct. I am only
relating what I have found on asc/McLaren corporate work, smuggled
out to me in the dead of night!! < grins >
> I don't think they put 3.73 in the 88 automatics. The reason I say
> this is because I recently had to pull my rear apart to fix a leaky
> rear axle seal and leaky rear pinion seal, and while I was in there
> counted the teeth and came up with 36 on the ring and 11 on the
> pinion, and that truns out to be around 3.27 when you do the math.
> My rear has never been replaced, and these are the gears that came
> with the car origionally. I was just wondering if this is
correct.
> I may be wrong and have miscounted, I am just curious. Anyone with
> an answer, thank you for your help.
> Anthony
> ***bE oRiGiNaL***
> > Hello Anthony !
> > Some Rumor! No where close to 300HP, they do produce 225 H.P.
> > They DID "hop-up" the rear end! In 5-Speed cars the standard
rear
> > was 2.73 & they upped it to 3.08. In automatic cars standard was
> > 3.23 & they hopped it up to 3.73.
