0960    <<    Message Index    >>    0962
Number: 0961
Date: Fri Jun 28, 2002  11:42 am
Subject: Re: Crossroads, your opinions.
I suggest trying to get that GT to run a tad cooler...I know you
said you've tried everything but I'll give it a try:
-160* thermostat,
-Aluminum big core radiator,
-Proper fan...make sure the factory clutch fan is working or if
you've switched to electric...make sure it is working properly...IE
coming on at the right temperature. Also, make sure you have a
shroud and that it is set up right...the shroud helps direct the air.
-Get a high flow waterpump or make sure the one you have is working
properly,
-Make sure you have good hoses,
-If you have pulleys...try putting the stock ones back on...sometimes
people have cooling and charging problems with pulleys,
-Good tune up...(last resort)...another last resort is to make sure
there is good airflow through the drill to the radiator.
That's all I have...Hope that helps...you've probably tried
everything I mentioned but if not...good luck.
Take Care,
Mike
--- In ascmclaren@y..., asc709 <no_reply@y...> wrote:
> Well, picked up an immaculate '99 Taurus yesterday. Car has only
> 27,000 miles on it. My dilema lies within...
> My 91 GT is mildly modded. The car runs H-O-T in the Sun City's
105+
> heat! I've done everything to solve the problem. Stuff helps, but
> nothing really fixes it. Should I...send it back to stock, sell it
> and use the $$$ to make the ASC absolutely immaculate (it doesn't
> need much) and use it as the daily driver? I mean, I drive the car
> once a week, but not every day. It has 104,000 on it already
> (although I am sure nobody can ever tell) so it's not a low mileage
> artifact. The GT is really nice, glossy black...people love it
more
> than the ASC!
> Who uses their McLaren every day?
> I do plan a teardown of the 10,000 mile motor in the GT before I
give
> up. I have the feeling everything is fine, though...
> I'm just thinkning out loud, I guess. Opinions help me dig deeper.
980 Re: Crossroads, your opinions. asc709 asc709 Sun  6/30/2002   4 KB
986 Re: Crossroads, your opinions. Marquis Grove InfoSysSec Tue  7/2/2002   3 KB
