2015    <<    Message Index    >>    2017
Number: 2016
From: "Sandy Block <cigarsandy@c...>" <cigarsandy@c...>
Date: Wed Feb 12, 2003  9:42 am
Subject: Re: springs
I assume that you have an '89 as listed in your signature. That
being the case, she is bone stock 1989 Mustang LX 5.0L underneath.
--- In ascmclaren@yahoogroups.com, "ascsbr <shortwalk@a...>"
<shortwalk@a...> wrote:
> Okay, here's a question for ya. When asc lowered our cars, did they
> cut the stock springs? Or, did they install specific rate springs
or
> progressive rate? Anyone know the actual spring rates, 800 lb., 420-
> 530 lb.,?? Also were the stock shocks changed out? Were any other
> mods done to the cars because they were lowered? Like,lower the
> steering rack, make adjustments to the alignment, etc. Did the cars
> come with a camber/castor plates?
> I ask because with the stock springs, I'm getting a little tired of
> hitting bumps and bouncing off the ceiling. It also feels as though
> I'm reaching the end of the limit of the shocks on compression.
With
> lowered springs should'nt you use specific shocks? Strange
> Engineering has adjustable struts and shocks at a great price.
> Anyone try them ??
> thanks
> steve '89 asc/Mclaren #123 blk./tan, 47,000 miles, strut tower
> brace, camber/castor plates, sub-frame connectors, 3:55 rear end,
> Tremac T5Z SHD 5 speed tranny, Flowmaster Delta Force catbacks,
> Steeda Tri-ax shifter, 4 wheel discs, BFG TA's 225/50/15's.
> Hibernating in my garage with fresh oil, a full tank of fuel with
> Stabil, battery stored inside, 4 coats of Zaino and under a Noah
> cover. Anxiously awaiting spring. Current temp in Lake St.Croix
> Beach, Mn. -9 below zero...........................sr
2018 Re: springs ascsbr <shortwalk@a...> ascsbr Wed  2/12/2003   3 KB
2019 Re: springs jdawg <jdawg@e...> ecstacycustomz2000 Wed  2/12/2003   4 KB
2020 Re: springs Sandy Block <cigarsandy@c...> cigarsandy Wed  2/12/2003   5 KB
