2721    <<    Message Index    >>    2723
Number: 2722
Date: Thu May 22, 2003  11:53 pm
Subject: Re: What's lost is now found...
Actually I thought about where the paint color should show up and
next to "XP" there is "Exterior Paint Colors". Was "XP" a mark for
a "special color" order? Much like the first gen Mustangs having
an "X" for their color code when they got painted a Tbird color?
So like who's to say this car wasn't white? Or were white coupes
ordered normally since white could be gotten on the RS (5.0) as well
as the GS? This car was probably built too early anyways to be a
white one.
Also, is there anyplace where it should say what COLOR the exterior
of the car should be. The code is 3L for blue but not found
anywhere on the tag.
Typo for Front GAWR...should be 3131LB
> I found the paper door tag for my car...nasty looking but still
> readable.
> Here is what it BARELY says...
> Date: 01/85
> Front GAWR: 131LB/966KG
> GVWR: 4060LB/1841KG
> REAR GAWR: 1949 LB/884 KG
> VIN: 1MEBP79M1FF607872
> Type: PASSENGER
> XP
> DSO: F0032
> R0073
> 236780
> Body: 61D
> VR: <blank>
> MLDG: <blank> (however maybe XP?)
> The XP that is beneath "PASSENGER" for "Type" is directly above
> MLDG. Maybe it was put on the wrong line?
> Int. Trim: PA
> There is a Y half way between "A/C" and "R". My guess would be
that
> the Y is YES for A/C.
> There is an M half way between "S" and "AX". My guess is that it
is
> for the axle. (poop, I was hoping for the 3.08 and not the 2.73)
> TR: 2BBBB
> I guess TR would stand for transmission but "2BBBB" seems like an
> odd code for a tranny.
2724 Re: What's lost is now found... negusm negusm Fri  5/23/2003   4 KB
2725 Re: What's lost is now found... negusm negusm Fri  5/23/2003   4 KB
2727 Re: What's lost is now found... Tom S. petedaycab Fri  5/23/2003   5 KB
2728 Re: What's lost is now found... Tom S. petedaycab Fri  5/23/2003   5 KB
2729 Re: What's lost is now found... negusm negusm Fri  5/23/2003   5 KB
