2796
2798
Number: 2797
Date: Thu May 29, 2003 10:23 am
Subject: Re: [ASC McLaren ] Those mysterious 1984s
It's not a problem with lateral force. It's a problem with oiling.
Hydraulic lifters need oil to be "pressureized". A flat tappet
hydraulic lifter has oil holes much lower than a hyrdaulic roller
lifter. The roller lifter is taller, and the oiling hole is
higher...how it's getting pressurized with oil in a flat tappet block
would be a mystery to me.
I know Crane and a couple other companies do make retro-fit roller
lifters for roller cams, but they also need reduced base-circle cams.
I think someone makes a retro-fit lifter to use a regular roller cam as
well.
76 Mercury Capri GHIA / 77 Mercury Capri RSX
http://www.mercurycapri.com
Still working on it!
Date: Wednesday, May 28, 2003 7:46 pm
> Just a side note here. The roller lifter blocks are different due
> to the
> taller lifter bores it's true but... People make them work just
> fine in
> older blocks all the time. Most lateral force on a lifter is at
> the base.
> (in a roller there's not much even there)
