3004
3006
Number: 3005
Date: Sat Jun 21, 2003 8:43 pm
Subject: Re: Anes ebay Air horns
When you put the "Stebel Junior" compressor next to the "Anes", they
appear identical except for the little yellow oil inlet at the top
of the "Anes". I guess you put some compressor oil in it once and a
while to keep it lubricated. Since there are internal spinning
parts. I think the Anes is an older version (1981). Most likely
made by the same company. They probably fixed the bearing inside
which required lubrication.
> Please explain to me the difference in the two compressors & the
oil
> thing....I have no "horn knowledge" ~ Thanks!
> > http://cgi.ebay.com/ws/eBayISAPI.dll?
> > ViewItem&item=2420168572&category=6763
> > If anyone is interested...Just ran accross another set of
these.
> > New and in the box. These are exactly the same air horns and
(very
> > nearly the same) compressor as goes on the 1985-1986 asc
coupes.
> > The only difference is that the compressor is not
stamped "Stebel
> > Junior" on top and has an oil inlet.
> > Great for a backup since Hank does not have originals anymore.
