3012
3014
Number: 3013
Date: Sun Jun 22, 2003 3:17 pm
Subject: Re: Anes ebay Air horns
Has anyone added these to a later year McLaren? I'm going to miss not
having it in the 89 as my 86 did have it.
Regards,
Eric
> When you put the "Stebel Junior" compressor next to the "Anes",
they
> appear identical except for the little yellow oil inlet at the top
> of the "Anes". I guess you put some compressor oil in it once and
a
> while to keep it lubricated. Since there are internal spinning
> parts. I think the Anes is an older version (1981). Most likely
> made by the same company. They probably fixed the bearing inside
> which required lubrication.
> > Please explain to me the difference in the two compressors & the
> oil
> > thing....I have no "horn knowledge" ~ Thanks!
> > S A N D Y
> > > http://cgi.ebay.com/ws/eBayISAPI.dll?
> > > ViewItem&item=2420168572&category=6763
> > > If anyone is interested...Just ran accross another set of
> these.
> > > New and in the box. These are exactly the same air horns and
> (very
> > > nearly the same) compressor as goes on the 1985-1986 asc
> coupes.
> > > The only difference is that the compressor is not
> stamped "Stebel
> > > Junior" on top and has an oil inlet.
> > > Great for a backup since Hank does not have originals anymore.
