3393    <<    Message Index    >>    3395
Number: 3394
Date: Fri Aug 29, 2003  9:06 am
Subject: Re: not sure
Re: not sure
It sounds like you might just have a two tone Capri 5.0/RS. The 140
speedo doesn't mean too much it could have been added by anyone over
the years. The Stock Capri 5.0/RS had a front air dam and two tone
paint scheme.
On the radiator there would be a smaller second tag that says McLaren
or some such thing. That is really the only way to tell unless there
are some tell tale parts like the orange wheels, asc steering wheel,
etc.
Here is a pic of my 2 radiator tags:
http://www.ascmclarencoupe.com/ascParts/asc_BodyBuckTag.jpg
Here is a pic of what the coupe should look like...the front air dam
will be different than the stock 5.0/RS:
http://www.ascmclarencoupe.com/Literature/ascMcLarenBrochures/85ascMcL
They did make white ones in 1985 too.
--- In ascmclaren@yahoogroups.com, amdkevin <no_reply@y...> wrote:
> How can i found out if i have a ASC Mclaren. I have a 85 mer capri.
> It showes 140 on the speed ometer all the ground efects. its a t-
top
> car its white the scope is black and the bottom under the trim is
> black. is there something somewhere in the vin or something that
will
> tell if its a ASC Mclaren. Thanks Kevin
3404 Re: not sure amdkevin amdkevin Fri  8/29/2003
3405 Re: not sure negusm negusm Fri  8/29/2003
3406 Re: not sure Sandy Block cigarsandy Sat  8/30/2003
3407 Re: not sure Tom G speedracer815 Sat  8/30/2003
3408 Re: not sure Sandy Block cigarsandy Sat  8/30/2003
3453 Wheel Restoration Tom G speedracer815 Tue  9/2/2003
3454 Re: Wheel Restoration SNP Marq infosyssec Tue  9/2/2003
3458 Re: Wheel Restoration Sandy Block cigarsandy Tue  9/2/2003
3461 Re: Wheel Restoration Tom G speedracer815 Wed  9/3/2003
