3576    <<    Message Index    >>    3578
Number: 3577
Date: Wed Sep 17, 2003  11:58 pm
Subject: Re: [ASC McLaren ] Need a parts car Capri
Yes, the Mustang parts may fit but most everything listed by Sandy
would not be correct on a Capri. That would also include the Capri
specific sail panels and front and rear mouldings that have the
reflectors in them. Also, the cowl for 83-86 Capri was the same as
the earlier Mustang/Capri 79-82 Cowl. The 83-93 Mustang Cowl will
not work quite right, its too big.
I think we finally agreed that the doors interchange as well as the
rear quarter glass. I checked and they are the same part number in
my part sheets.
Exterior pieces that are shared between the Mustang and Capri(83-86):
doors, side mirrors, glass mouldings (except around hatch), drip
mouldings, mid level body mouldings on doors, LX/GS moulding between
doors and wheels, quarter glass, headlights, front inner fender
splash guards, antenna bezel, probably a few more things.
Things that can be used from the Mustang on a Capri but are not
correct for a Capri (83-86):
You are right, most everything will interchange. Front bumper cover
if you also use the bumper headlight support. The hood if you also
use the newer/larger 83-93 Mustang Cowl. Rear bumper cover, Not
sure on the tail lights but I've seen it done. "GT" body side
mouldings, front fenders, hatch, sail panels, maybe a few more odds
and ends.
Almost everything internally is the same, drive train, suspension,
interior. The only thing I can think of would be the steering wheel
would have a cat on it instead of "Ford" for the Mustang.
--- In ascmclaren@yahoogroups.com, Cain Aaron Jr <caaron73@y...>
> You guys are crazy I'm using an old 86 mustang now and all the
parts fit perfectly on my 85 ASC McLaren that is being restored. My
friend has an 86 Capri RS that he used the 85 mustang hatch to
replace the bubble Capri hatch and it fits perfect.
> ho660 <no_reply@yahoogroups.com> wrote:Aren't the doors the same?
I thought only the mouldings were
> different.
> > On the exterior, there is very, very little that is shared! One
> > cannot use hoods, outer door skins, front fenders nor rear
> quarters,
> > not hatch nor rear window glass or side rear quarter windows,
not
> > grilles or lower front facias or rear taillamps not their lower
> rear
> > bumper fascia. About the only shared parts are the windshields
> > door windows. Inside, however that are many shared parts.
> > > Yes, but not for Quarter Panels or Fenders which is what I
need.
<caaron73@y...>
> > > wrote:
> > > > You know that you can also use mustang parts right?
> > > > negusm <negusm@y...> wrote:Yes, the body shop has gotten to
> > looking
> > > at the coupe and they don't
> > > > like what they see. The repair made by the previous owner
in
> > > Florida
> > > > was a terrible job and I need a donor Capri with good
quarters
> > > and/or
> > > > roof. Basically the whole ass end is f$ucked up.
> > > > Anyone know of a junkyard with a parts car Capri? Anywhere
> from
> > > > Rochester, NY to Boston Mass might be acceptable.
Preferrably
> in
> > > and
> > > > around Albany, NY area would be best.
> > > > I'm seriously thinking about not fixing this coupe and just
> > buying
> > > > the $7500 coupe that is now on www.ascMclaren.com and
> stockpiling
> > > all
> > > > the coupe parts I bought.
> > > > But like I said before...I'm on a mission from god.
> > > > -Mike
3579 Re: Need a parts car Capri Cain Aaron Jr caaron73 Thu  9/18/2003
3582 Re: Need a parts car Capri negusm negusm Thu  9/18/2003
