4048    <<    Message Index    >>    4050
Number: 4049
Date: Mon Dec 1, 2003  9:22 pm
Subject: Re: [ASC McLaren ] Digest Number 518
I suppose that could happen to an injector.  Please also know that usually when they have problems is is due to the spray pattern into the engine getting messed up (due to and obstruction in the nozzle or a crack)  You can't see when this is happening.  Usually you would also have a miss and the car would run like junk.
I still say it's the O2 sensor.
Can't hurt to replace anyway.  If they are original they are mighty tired anyway.
John
Sent: Monday, December 01, 2003 8:38 PM
If it was a fuel injected 5.0 then I would suspect a faulty injector....    I had one 'go bad' and the smell of gasoline vapors was quite wicked.
And you can usually only spot it with the engine running.  I forgot exactly what it is that 'goes' on them, but I think it was some kind of  o ring.  The fuel spurts out on to the engine block... and evaporates rapidly because of the heat of the engine and manifold... so it leaves little evidence behind except the strong vapor smell.  You need to have the engine running and a flashlight to spot it while it is occuring... in order to zero in on which one the fuel is spurting out of.
Marq
Sent: Monday, December 01, 2003 8:18 PM
She says "Raw, unburnt gas"  Like standing next to a gas pump taking
deep breaths as the fuel goes into the car....
-- In ascmclaren@yahoogroups.com, Peter Shear <tfs2121@y...> wrote:
> is it a gas smell or is it like rotten eggs rotten egg
> smell is caused by the cat being cloged or a bad O2 if
> its a fuel thing it can still be the O2 and it sounds
> like it might be
> ~Peter
> > Free Pop-Up Blocker - Get it now
> http://companion.yahoo.com/
4050 Re: Digest Number 518 Sandy Block cigarsandy Mon  12/1/2003
4051 Re: Digest Number 518 Sandy Block cigarsandy Mon  12/1/2003
4052 Re: Digest Number 518 negusm negusm Tue  12/2/2003
