4397    <<    Message Index    >>    4399
Number: 4398
Date: Mon Jan 26, 2004  10:09 pm
Subject: Re: door swap
Re: door swap
The doors on a 85 Mustang are the same as the Capri. The holes,
wiring, etc, should all the the same. On my car I had a Mustang
door swapped with the Capri door and there was no difference. Yes,
you need to move the glass and stuff over.
Now, the doors on an 85 Mustang CONVERTIBLE may not be exactly the
same. asc cut the window frame off the door when they did their
conversion. They may also have done a few other modifications. An
85 GT convertible would have doors modified by Cars & Concepts and I
doubt they cut the window frame off in the same way as asc. I THINK
they also added some door bumpers to keep the fit of the door tight
against the body so that flexing or warping would be minimized.
However, as I've never seen an asc vert door or a Mustang vert door,
a Mustang vert door may actually be less work if you find a good one.
Some people at www.foureyedpride.com have taken hatchback/notchback
doors and converted them to vert doors by trying to follow what CC
did. It was work but they have been successful.
As always correct me if I'm wrong.
--- In ascmclaren@yahoogroups.com, "merstang85" <erndog02@e...>
> Hi I was curious if anyone has tried to swap doors between a 85
> Mclaren convert and a 85 GT stang. I know the windows would need
> be exchanged and some trim. Are there any issues with the wiring
> harness, both have power locks and windows.
> P.S. Sandy Only the cat.
4400 Re: door swap merstang85 merstang85 Mon  1/26/2004
4401 Re: door swap negusm negusm Mon  1/26/2004
4402 Re: door swap Tom G speedracer815 Tue  1/27/2004
4403 Re: door swap negusm negusm Tue  1/27/2004
4404 Re: door swap Sandy Block cigarsandy Tue  1/27/2004
4405 Re: door swap Sandy Block cigarsandy Tue  1/27/2004
4406 Re: door swap negusm negusm Tue  1/27/2004
4407 Re: door swap Sandy Block cigarsandy Tue  1/27/2004
4408 Re: door swap Tom G speedracer815 Tue  1/27/2004
