I have PPG # 33717 "Flat Gray" Listed under BLACKOUT COLORS. However, there is also a "Flat Black" with # 9381.
On my can, there is a paint smear over the hand written number, and it's very hard to read (faded & smeared.)
What # you got ??
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > OK, thanks for the heads up. Whats the ditzler number for the > charcoal paint? > > I have a number and want to verify that it's correct. > > -Mike > >
--- In ascmclaren@yahoogroups.com, "Sandy Block" <cigarsandy@c...> > wrote: > > Mike, the installation of the L shaped aluminum charcoal colored > > frame that the plexiglas window slides into can be tricky. If I > am > > not mistaken, the frame gets pop rivited in at 3 points. However, > it > > it is not set "just so" when you go to screw in the vertical > seperate > > piece that rides up & down the "B" pillar, your door's frame (top > > corner) will strike it and NOT allow the door to close. You'll > need > > extra sets of arms & hands to get it done correctly, and it's very > > tricky. The tolarances are millimeters, and the fit has to be > super > > tight to prevent water from entering and getting trapped. If I > can > > recall they are 3/8th screws to fit thru the holes in the B- Pillar > > finishing piece. IF yours are NOT painted charcoal, ask, because > I > > have the paint code # (DuPont Ditzler) > > > > S A N D Y > > > > > > -- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > > > Hanks got it. > > > > > > I ordered some. I didn't ask what he charges, I never do. I > just > > > pay for sh!t at this point. > > > > > > -Mike > > > > > >
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > > > > bah, yet ANOTHER part to buy :-) > > > > > > > > -Mike > > > > > > > >
--- In ascmclaren@yahoogroups.com, "Sandy Block" > > <cigarsandy@c...> > > > > wrote: > > > > > Click onto the link that Peter supplied, from J.C. > Whitney. > > > Look > > > > at > > > > > #3 (top row across). > > > > > > > > > > I took mine apart years ago to clean the water spots off and > > > that > > > > is > > > > > what sat IN the aluminum frame, which itself is shaped like > > > a "U" > > > > all > > > > > the way around. The purpose of it was clear to me, to keep > the > > > > lexan > > > > > plastic black out window panel from rattling in the aluminum > > > track > > > > in > > > > > which it sits. The piece we are talkig of was "fuzzy" like > > felt > > > > on > > > > > the inside of the "U" and rubbery on the outside of the "U". > > > > > > > > > > Hank might have some. I think he does!! > > > > > > > > > > S A N D Y > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
--- In ascmclaren@yahoogroups.com, Peter Shear > <tfs2121@y...> > > > > wrote: > > > > > > i THINK this is what it is > > > > > > > > > > > > > > > > > http://www.jcwhitney.com/webapp/wcs/stores/servlet/ProductDisplay? > > > > > makeId=1000130&productId=3258&catalogId=10101&langId=- > > > > > 1&modelId=1001513&storeId=10101 > > > > > > > > > > > > ill try sending you a pic > > > > > > > > > > > > __________________________________ > > > > > > > > > > > Mail SpamGuard - Read only the mail you want. > > > > > > http://antispam.yahoo.com/tools
