4672    <<    Message Index    >>    4674
Number: 4673
Date: Wed Mar 10, 2004  2:40 pm
Subject: Re: [ASC McLaren ] Re: Interesting figures
I hit the send button too fast, so I'll start again.
I always assumed that HB is for HatchBack, but after some looking that
doesn't make sense because that is what the "61D" means.
This "HB" code appears in the same location on a Mustang buck tag and the
Mustang GT Registry also does not know what that code means but their
suspicion is that it possibly could be a rear defroster code.
Thanks for the info on my car Sandy, I had gotten most of it from you back
when I found the car sitting on a used car lot and called you to confirm
what it was before I bought it. What I didn't have were the recieving &
shipping dates or the production line figures of how many Capri's were built
after mine, that's some pretty neat info.
Brent
Sent: Wednesday, March 10, 2004 2:24 PM
Subject: Re: [ASC McLaren ] Re: Interesting figuresI always assumed that HB is for HatchBack.
Sent: Wednesday, March 10, 2004 2:13 PM
Subject: [ASC McLaren ] Re: Interesting figures> Obviously I messed up! The HB is NOT the build date! Could not have
> been built in August & received in July! The HB is NOT the build
> date. I don't know what it stands for. The McLaren dates of
> receiving & shipping are indeed correct.
> SORRY
> > 618892 is a EuroCoupe, Oxford White. Received AT ascMcLaren on July
> > 15th 1986 & shipped out on July 24th 1986. It's the 13th of the 47
> > EuroCoupes. They made 34 after it. It's one of 14 in color.
> > Regarding the Buck-Tag:-
> > 618892 is of course your sequence VIN. 61D is the code for a Capri
> 3-
> > Door Hatchback. The "M" is the code for the 302 Cu In V-8 with EFI.
> > 9L is the code for Oxford White, while the PW is Power Windows.
> > The HB is the build date of August 2nd H=Aug B=2 They built 1,977
> > 1986 Capris AFTER yours.
> > Mustang took 93% of the build and Capri took 7% of the Dearborn
> 1986
> > model year build, which was 245,279, or 20,869 Capri & 224,410
> > Mustang.
> > S A N D Y
> > > I don't have my door tag info handy but my body buck tag reads as
> > follows:
> > > CAPRI
> > > 618892 61D M 0127
> > > 9L DF ST
> > > AC 06 HB
> > > PW 02
> > > A EI 06 2 X 2 NLR
> > > And of course the other smaller tag next to it that reads:
> > > MCLAREN COUPE
> > > MCLAREN COUPE
> > > MCLAREN COUPE
> > > Brent
> > > 1986 EuroCoupe, White, Automatic
> > > From: "negusm" <negusm@y...>
> > > Sent: Wednesday, March 10, 2004 10:59 AM
> > > > Yes, it would be nice if we could get some owners to post more
> of
> > > > their buck tags, door tags and any legible build sheets.
> > > > My door tag as everyone probably has seen before is:
> > > > http://www.ascmclarencoupe.com/History/MasiBefore/door_tag.jpg
> > > > My buck tag is here but I don't have the info on it:
> > > > http://www.ascmclarencoupe.com/ascParts/asc_BodyBuckTag.jpg
> > > > Its in front of the radiator attached to the cross bar.
> > > > -Mike
> > > > > Again, the door tag DSO is different than the internal DSO
> > code.
> > > > > The door tag DSO is for the District Sales office. This 2
> > digit
> > > > > code merely shows what district the car is/was intended for.
> > For
> > > > > cars that were special orders there is an additional 4 digits
> > that
> > > > > are undecipherible without internal paperwork.
> > > > > D32 is a code Ford used internally at the plant to identify a
> > > > > McLaren build.
> > > > > IF everybody would offer up their door tag info we could try
> to
> > > > > narrow down what codes are common for these cars and use
> those
> > > > also
> > > > > as identifiers. For instance, maybe all McLaren Capri coupes
> > had
> > > > > the same DSO or maybe they all used the same spring codes
> which
> > is
> > > > > coded with the transmission on the tag or maybe they all have
> > > > > same Accesory Reserve Load codes that is printed above the
> DSO
> > on
> > > > > the door tag. This could be done for the Coupes, Capri verts
> > and
> > > > > the Mustangs also. There is nothing except the VIN on this
> tag
> > to
> > > > > identify the car so a picture or two of the tag, with only
> > > > last
> > > > > 6 digits of the vin blocked out if you so choose, would be
> > great.
> > > > > If Sandy wants to handle the load of pics or if Negusm wants
> to
> > > > > fine, or I can too. A few examples of the tags:
> > > > > http://www.sspmustang.org/technical/doortags.htm
> > > > > Tom S.
--- In ascmclaren@yahoogroups.com, Peter Shear <tfs2121@y...>
> > > > wrote:
> > > > > > what about the door tag would it say anything about
> > > > > > the D32 build code or something?
> > > > > > ~Peter
> > > > > > __________________________________
> > > > > > > > > > > Search - Find what you're looking for faster
> > > > > > http://search.yahoo.com
> > > Groups Links
Groups Links
4742 Re: Interesting figures negusm negusm Sun  3/14/2004
4772 Re: Interesting figures ascmclarencoupe ascmclarencoupe Mon  3/15/2004
4773 Re: Interesting figures negusm negusm Mon  3/15/2004
4777 Re: Interesting figures Sandy Block cigarsandy Tue  3/16/2004
