5045
5047
Number: 5046
Date: Wed May 19, 2004 10:11 pm
Subject: Re: [ASC McLaren ] top not working...
i took some pics for you but i couldn't open the photo section
(again) so i put them on my web site.
http://www.ecstacycustomz.com/gallery/view_album.php?
set_albumName=projects
click on the last album labeled "asc"
there is a pic of the switch pulled out and wires exposed, a pic of
the pull down motor, and a pic of the saftey switch in the trunk--
this might also be your problem. if its not making contact with the
trunk hindge when the trunk is closed the top motor will not work.
you can tape it to test everything else. its a plunger type switch.
it prevents the tonnou frow coming up when the trunk is open, so you
dont crush the body and trunk edges.
jdawg
--- In ascmclaren@yahoogroups.com, "Dan the Man" <damntheman23@y...>
> wow...um ya pics would be great just as a backup....i really
> appreciate your time and help....thanks
--- In ascmclaren@yahoogroups.com, "ecstacycustomz"
> <ecstacycustomz@y...> wrote:
> > it real simple to test the switch. pull it out, on the back
there
> > are 3 wires--1 hot lead, and 2 others one wire releases the top
> and
> > the other operates the pull down motor.just pull off the outside
> > wires one at a time and touch them to the center wire. again
one
> > should pop the release, and the other will pull down the top.
if
> > the pull down wont work this way then you know its the motor, if
> it
> > does work then its the switch. one has nothing to do with the
> > other, the release mechanism is in the tonnou and the pull down
> > motor is in the trunk. also note that these 2 items run off a
> self
> > grounding system(no wire), so you might also check to make sure
> > there is no build up on the contact points.
> > jdawg
> > p.s. if you need pics just ask
> <damntheman23@y...>
> > > ok you think it would be the switch and not the top motor?
> > because
> > > when i first bush the switch up the hard cover that holds the
> top
> > > actually pops up and after that the motor is supposed to spin
> > > screw up and bring the back of the convertible top up so it
can
> be
> > > stowed away and its this part thats not working...same
> difference
> > if
> > > i close the lid and press down on the switch to have the top
> > screwed
> > > back into the car...that doesnt work either...
--- In ascmclaren@yahoogroups.com, Troy Allan Hobbs
> > > <tallanhobbs@y...> wrote:
> > > > sounds like your switch is going bad, I had the same issue
> with
> > my
> > > 87 recently, I removed the switch and cleaned up the contacts.
> It
> > > was a temporary repair, but got me thru til I got the new
switch.
> > > > Troy
> > > > Dan the Man <damntheman23@y...> wrote:
> > > > ok i have an 89 mclaren and the top has stopped working...i
> can
> > > > click the button and the back will release and pop up but
> > > motor
> > > > wont spin the screw up anymore...is this a definate sign of
a
> > bad
> > > > motor?? it wont close the top all the way either...the top
is
> > > > closed but not screwed down all the way....any help would be
> > > > appreciated and thanks for letting me be a member of this
> great
> > > > group...
> > > > daniel
> > > Groups Links
> > > > To visit your group on the web, go to:
> > > > http://groups.yahoo.com/group/ascmclaren/
> > > Terms
of
> > > > > > > > SBC Yahoo! - Internet access at a great low price.
