5232    <<    Message Index    >>    5234
Number: 5233
Date: Tue Jul 13, 2004  3:37 pm
Subject: Re: 85-86 Dark Charcoal Trim Codes
I probably will eventually. I want to see the pics of this stuff
when this guy gets his car painted here this week.
Problem is, I don't know how much better it will be for "touch up"
work.
Dabbing the 33717 paint that you already have onto your small area
on the driver's side trim probably produces a satin-like effect
anyways.
If you take "satin" (or flat) spray paint and brush it on a surface,
it will be more glossy than if you spray it on. If you spray a
satin paint on EXTREMELY THICK you can achieve a very glossy
appearance too. You can also take a GLOSSY paint and on a dry day,
hold the can far away (so the paint starts drying in mid flight) and
achieve a Satin or "Matte" effect.
But sure, if I get some made up, I'll be glad to send you a pint. I
don't know if you'll need to mix the reducer or dcx61 in before
touching up or not.
> WoooHooo
> Get some made up Mike and I'll buy a pint from you.
> > I finally found someone who looks like they have the right
formula
> > for the 85-86 Dark Charcoal trim!
> > A guy at FEP has a car being painted and the painter used to
> restore
> > Fox Mustangs and had a formula for getting the correct FINISH
for
> > the paint. The 33717 paint code IS the right color but if mixed
> > like normal (in a base coat) it comes out WAY too FLAT. Then
when
> > clear coated its WAY shiny. The following should mix a quart of
> > 33717 single stage paint that should be SATIN!
> > Here's the formula for 33717 single stage. its based
> > on a quart can of mixed color. the manufacture is PPG.
> > code color parts
> > dmc902 black 226.6
> > dmc900 str. whi 215.8
> > dmc901 str. bla 137.5
> > dmc929 lt red 76.0
> > dmc904 blue 38.5
> > dx995 matt bas 421.9
> > additional notes:
> > mix 6 pts paint - 2 pts dt reducer - 1 pt dcx61
> > special low gloss color
> > this is the correct color for all body side molding and trim for
> > 1986 mustang gt - charcoal.
5234 Re: 85-86 Dark Charcoal Trim Codes Sandy Block cigarsandy Wed  7/14/2004
5235 Re: 85-86 Dark Charcoal Trim Codes Sandy Block cigarsandy Wed  7/14/2004
5236 Re: 85-86 Dark Charcoal Trim Codes negusm negusm Wed  7/14/2004
