5282    <<    Message Index    >>    5284
Number: 5283
Date: Fri Jul 30, 2004  3:45 pm
Subject: [ASC McLaren ] Re: Stebel Junior Air Horns
Since 1989 & 1990 did not have it, the car that did were 1984-1987.
I am not too sure about 1988 (???). So, I guess the earlier ones
would be 1984-86 and later might be 1987 & 1988 ???
> It appears the earlier ones used oil for lubrication.
> The later ones used graphite for lubrication. I was cleaning the
> one I have that didn't have the oil inlet and blackpowder was
coming
> out of the top.....which looked just like graphite.
> > Why then the oil inlet? Is it necessary? Why would some have,
> and
> > some have not?
> > S A N D Y
--- In ascmclaren@yahoogroups.com, "Mike Negus" <negusm@y...>
> > > Sorry, the ONLY thing different is that it has the oil inlet in
> > it. Ours do
> > > not.
> > > The compressor is identical in every other way....I have both
> > versions now.
> > > Those horns look to be EXACTLY the same as the ones I have from
> my
> > car.
> > > ----- Original Message -----
> > > From: "Sandy Block" <cigarsandy@c...>
> > > To: <ascmclaren@yahoogroups.com>
> > > Sent: Friday, July 30, 2004 1:23 PM
> > > > What makes it "NEARLY-exact" rather than "IDENTICAL" ????
> > > > In detail, please, if you can...
> > > > S A N D Y
> > > > > http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?
> > > > > ViewItem&item=7913233907
> > > > > I talked with the guy and this says "Stebel Junior" on
top.
> It
> > > > does
> > > > > have the oil inlet valve on it but this is NEARLY the EXACT
> same
> > > > air
> > > > > horn and compressor setup as what is on our cars.
> > > > > -Mike
> > > Groups Links
