5283    <<    Message Index    >>    5285
Number: 5284
Date: Fri Jul 30, 2004  4:27 pm
Subject: Re: [ASC McLaren ] Re: Stebel Junior Air Horns
By "early" imean the airhorns with the oil cap were made in ~1977.
Stebel must have moved to the graphite (non oil cap) by 1984.
Sent: Friday, July 30, 2004 3:45 PM
Subject: [ASC McLaren ] Re: Stebel Junior Air Horns> Since 1989 & 1990 did not have it, the car that did were 1984-1987.
> I am not too sure about 1988 (???). So, I guess the earlier ones
> would be 1984-86 and later might be 1987 & 1988 ???
> > It appears the earlier ones used oil for lubrication.
> > The later ones used graphite for lubrication. I was cleaning the
> > one I have that didn't have the oil inlet and blackpowder was
> coming
> > out of the top.....which looked just like graphite.
> > > Why then the oil inlet? Is it necessary? Why would some have,
> > and
> > > some have not?
> > > S A N D Y
--- In ascmclaren@yahoogroups.com, "Mike Negus" <negusm@y...>
> > > > Sorry, the ONLY thing different is that it has the oil inlet in
> > > it. Ours do
> > > > not.
> > > > The compressor is identical in every other way....I have both
> > > versions now.
> > > > Those horns look to be EXACTLY the same as the ones I have from
> > my
> > > car.
> > > > -Mike
> > > > From: "Sandy Block" <cigarsandy@c...>
> > > > Sent: Friday, July 30, 2004 1:23 PM
> > > > > What makes it "NEARLY-exact" rather than "IDENTICAL" ????
> > > > > In detail, please, if you can...
> > > > > S A N D Y
> > > > > > http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?
> > > > > > ViewItem&item=7913233907
> > > > > > I talked with the guy and this says "Stebel Junior" on
> top.
> > It
> > > > > does
> > > > > > have the oil inlet valve on it but this is NEARLY the EXACT
> > same
> > > > > air
> > > > > > horn and compressor setup as what is on our cars.
> > > > > > -Mike
> > > > Groups Links
Groups Links
