0632    <<    Message Index    >>    0634
Number: 0633
Date: Sat Mar 9, 2002  2:19 am
Subject: Re: 88 McLaren
I don't think they put 3.73 in the 88 automatics. The reason I say
this is because I recently had to pull my rear apart to fix a leaky
rear axle seal and leaky rear pinion seal, and while I was in there I
counted the teeth and came up with 36 on the ring and 11 on the
pinion, and that truns out to be around 3.27 when you do the math.
My rear has never been replaced, and these are the gears that came
with the car origionally. I was just wondering if this is correct.
I may be wrong and have miscounted, I am just curious. Anyone with
an answer, thank you for your help.
Anthony
***bE oRiGiNaL***
> Hello Anthony !
> Some Rumor! No where close to 300HP, they do produce 225 H.P.
> They DID "hop-up" the rear end! In 5-Speed cars the standard rear
> was 2.73 & they upped it to 3.08. In automatic cars standard was
> 3.23 & they hopped it up to 3.73.
635 Re: 88 McLaren cigarsandy cigarsandy Sat  3/9/2002   3 KB
638 Re: 88 McLaren n20capri n20capri Sat  3/9/2002   3 KB
636 Re: 88 McLaren n20capri n20capri Sat  3/9/2002   3 KB
637 Re: 88 McLaren cigarsandy cigarsandy Sat  3/9/2002   4 KB
639 Re: 88 McLaren hanksgt hanksgt Sat  3/9/2002   4 KB
646 Re: 88 McLaren ho660 ho660 Sun  3/10/2002   5 KB
650 Re: 88 McLaren asc88mclaren asc88mclaren Mon  3/11/2002   4 KB
653 Re: 88 McLaren cigarsandy cigarsandy Mon  3/11/2002   5 KB
657 Re: 88 McLaren n20capri n20capri Mon  3/11/2002   6 KB
