And thats another thing that goes through my head about the 'B' cam. You realize that could be a reason that ALL record were lost on the 85's. So no one could prove that the motor was actually emissions illegal... (Just a thought).....Jason
--- In ascmclaren@yahoogroups.com, John Gemelli <jgemelli@o...> wrote: > Yep the car I was speaking of is a coupe. Something else to tell you. The > B303 was Motorsports first roller cam offering. If you notice the B303 was > not because the camshaft never got an EO#. In other words it was not legal > to sell it on any productions vehicle that was ever to see the public > highways. Sandy's description of it should tell folks why. > The E303 was emissions exempt and could have been widely advertized by ASC > had it been available in 1985. It was not, nor was the F303 > > My .02 > John (3 asc's) > > ----- Original Message ----- > From: "Sandy Block" <cigarsandy@c...> > To: <ascmclaren@yahoogroups.com> > Sent: Friday, November 28, 2003 8:30 PM > Subject: [ASC McLaren ] Re: 85 Coupe Questions > > > The car's a COUPE, correct??? > > Okay, the axle ratio thing was an oversight! ascMcLaren did not > think to check out the FoMoCo installed gearing, until mid- production > build of '85. The 2.73:1 was Std. in the GT with the 3.08:1 as a no- > charge option. The 3.08:1 shoulda been included with the D32 build, > so that ALL cars got it, but it wasn't. This was corrected for > the '86 build. Furthermore, SOME (I do not know what mandated it!!) > but SOME '86's had the 3.73:1 ratio, as does mine. Perhaps, > again....a No Charge Option ???? > However, the 3.73:1 was NOT (repeat...NOT) available on an '86 Coupe > with the 5-Speed Manual......only with the Automatic Transmission. 5- > Speeds got the 3.23:1. Nobody got the 2.73:1 and 5-speeds got the > 3.08:1. While most automatics got the 3.23:1. Confused yet? > Coupes...no 'verts got the B-303. I never heard of an E-303, but > these cars were so confused, nothing surprises me any longer! > You can tell if your car has 303 as if it does, it will be lumpy, > lumpy, lumpy at red lights, and when cold ! It will also sometimes > stall about 3 minutes into "Warm-Up" on a cold AM. > > S A N D Y > > > >
--- In ascmclaren@yahoogroups.com, "capri_16t" <capri_50@m...> wrote: > > Good to know Sandy. Thank you. I just thought ALL came with 3.08s. > > Didn't realize it was an option. My 88 ASC has 3.08's, but didn't > > realize it was standard at that time and not before. Everyday I > > find something a little different on the 85s. My 85 also came with > > an 85mph speedo. I know I read somewhere that most were suppose to > > come with a b-303 cam, but I don't seem to hear the typcial > duration > > sound that i am use to hearing when a regular mustang changes their > > stock grind to a B-303. My other 86 regular capri 5.0 with an E- > 303 > > sounds a lot more impressive than whatever this cam is. Is it > > possible that mine is a regular stock 85 cam or I am expecting to > > hear something out of a B-303 that really isn't there.....???? It > > also amazes me that Ford would have put a B-303 cam in their since > > the FORD intake cuts off breathing WAY before their own B-303 likes > > to operate and a 2.73 gear isn't hardly enough for a B-303.... But > > I have seen FORD do a lot more crazy things than that.... Give me > > some more info SANDY.... :) > > > > > > Jason > > > >
--- In ascmclaren@yahoogroups.com, "Sandy Block" <cigarsandy@c...> > > wrote: > > > 1985's came with 2.73:1. The higher ratio was then a no-charge > > > option, and became standard in the 1986's. (We're talkin' coupes > > > here). > > > > > > S A N D Y > > > > > > > > > > > >
--- In ascmclaren@yahoogroups.com, "capri_16t" <capri_50@m...> > > wrote: > > > > Have an interesting question. I have an 85 Blue/orange capri. > > > Door > > > > sticker denotes axle code is 'M'. I thought 'M' is for 2.73's > > > > and 'Z' was for 3.08's. Did the 3.08's not get installed in > the > > > > rear until later (before the decal was made) or is this one of > > > those > > > > MANY freak mistakes which I happen to have by FORD and/or > > Mclaren. > > > > > > > > > > > > Jason > > > > > > > > > > > >
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > > > > > Sandy's Post #356 kind of describes it. There were no > > documented > > > > > options but it seems there were some undocumented ones on the > > > last > > > > > of the '85s. > > > > > > > > > > -Mike > > > > > > > > > >
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> > > wrote: > > > > > > Yeah, I pulled that out from an old posting. I think Sandy > > > > > > clarified that actually some of the later 85's had some > > options > > > > > > added. > > > > > > > > > > > > -Mike > > > > > > > > > > > >
--- In ascmclaren@yahoogroups.com, John Gemelli > > <jgemelli@o...> > > > > > > wrote: > > > > > > > Maybe I misunderstand your chart but I think it's wrong > on > > > the > > > > > > 85's as my > > > > > > > Midnight blue coupe has > > > > > > > Pop up sunroof, Power locks and a Remote hatch release in > > the > > > > > > glovebox. > > > > > > > > > > > > > > John > > > > > > > ----- Original Message ----- > > > > > > > From: "negusm" <negusm@y...> > > > > > > > To: <ascmclaren@yahoogroups.com> > > > > > > > Sent: Thursday, April 10, 2003 9:56 PM > > > > > > > Subject: [ASC McLaren ] Re: 85 Coupe Questions > > > > > > > > > > > > > > > > > > > > > > Well the following I gleaned from all the postings as I > > went > > > > > > > > through... > > > > > > > > > > > > > > > > Most of it is from sandy and I think it is fairly > > > accurate. > > > > It > > > > > > > > hasn't been cleaned up and may be somewhat > jumbled...but > > > > here > > > > > it > > > > > > > > is...correct anything if it is wrong... > > > > > > > > > > > > > > > > Coupe information: > > > > > > > > > > > > > > > > Mercury Capri Coupe GS, tagged with an ASC Mclaren body > > tag > > > > > and a > > > > > > > > Ford code of D32 to > > > > > > > > denote special order. > > > > > > > > > > > > > > > > Standard Equipment: > > > > > > > > These items were Extra in the Mustang GT, but Standard > > in > > > > ALL > > > > > > Capri > > > > > > > > RS (GS?) 5.0L cars, and therefore also in all > > asc/McLaren > > > > > Coupes, > > > > > > > > from the Dearborn Assembly Plant. > > > > > > > > > > > > > > > > 1. Power Windows > > > > > > > > 2. Light Group > > > > > > > > 3. Electric Rr. Defroster > > > > > > > > > > > > > > > > Items standard in the Mustang GT and Capri: > > > > > > > > 1. Tinted Glass > > > > > > > > 2. Tilt Steering Wheel > > > > > > > > > > > > > > > > Options (From Ford) Installed ON LINE at Dearborn on > OUR > > > > > COUPES, > > > > > > > > were: > > > > > > > > 1985 > > > > > > > > NONE > > > > > > > > 1986 > > > > > > > > Power Door Locks > > > > > > > > Remote Hatch Release > > > > > > > > Air Conditioning (Standard in 1985) > > > > > > > > Speed Control > > > > > > > > Pop-Up Sun Roof > > > > > > > > T-Roof > > > > > > > > Automatic Transmission > > > > > > > > > > > > > > > > All, except the Air Conditioning which was standard in > > 1985 > > > > > > > > (optional in 1986) were NOT available on 1985s. > However, > > > > very > > > > > > near > > > > > > > > the end of production of the 1985's asc/McLaren > > > > added "Oxford > > > > > > White" > > > > > > > > as an alternative color choice to the "Midnight Navy- > > Blue > > > > > > Metallic", > > > > > > > > and at that point, and only on the Oxford White cars, > > they > > > > > > allowed > > > > > > > > the option of Power Door Locks/Remote Hatch release, > and > > > > Speed > > > > > > > > Control. > > > > > > > > > > > > > > > > NO 1985s had the Pop-Up Sun Roof, nor the T-Roof, nor > > > > Automatic > > > > > > > > Transmission. 1985s in Oxford White with Pwr. Locks & > > > Speed > > > > > > Control > > > > > > > > are EXTREMELY rare, and I have only 2 on the asc/McLaren > > > > > > > > International Registry, after keeping the Registry now > > for > > > > 16 > > > > > > years! > > > > > > > > > > > > > > > > Of the 1986's, just nine (9) were equipped with the > > > Automatic > > > > > > > > Transmission, and the Pop-Up Sun Roof was on around 20 > > > cars, > > > > > > while > > > > > > > > the T-Roof was on around 30 cars. Power Locks were on > > > around > > > > 55 > > > > > > > > cars. I have never found an '86 withOUT A/Cond. The > > rarest > > > > > combo > > > > > > > > would have been an '86 in Platinum Silver Metallic with > > > > Raven > > > > > > Black > > > > > > > > decals/logos/stripes, with a T-Roof, Pwr. Locks, > > Automatic > > > > > Trans. > > > > > > > > However, no such car was built! > > > > > > > > > > > > > > > > > > > > > > > > Engine Oddities in 1985: > > > > > > > > > > > > > > > > Odd Sized Piston Rings...Normal ones are TRW Metric Some > > > > > > > > Ford Mustang 1.5mm.-1.5mm-4mm oil ring > > > > > > > > Mercury Capri 1/16-1/16-156mm oil ring > > > > > > > > > > > > > > > > Some parts scribed with a P for PROTOTYPE by hand > (Valve > > > > > Guides, > > > > > > > > Springs, etc). > > > > > > > > > > > > > > > > Herewith are the actual alterations done to the MOTOR, > > > > either > > > > > by > > > > > > > > Ford (F) > > > > > > > > or by asc/McLaren (AM) > > > > > > > > > > > > > > > > A) Upgrade Exhaust Header to Stainless Steel Internal > > > > Mandrel > > > > > > Bent > > > > > > > > Incorporate Exhaust Port Liners Tuned With Lower > > > Restriction > > > > > > Exhaust. > > > > > > > > B) Tuned Muffler To Reduce Back Pressure & Enhance > > Exhaust > > > > > Tone. > > > > > > > > C) Replace Damper Units & Springs To Achieve Better > > > > Cornering > > > > > & A > > > > > > > > Softer > > > > > > > > Ride than The TRX System. > > > > > > > > D) Modify Camber Of Vehicle Front & Rear To Maximize > > > > > Performance > > > > > > Of > > > > > > > > Upgraded > > > > > > > > Tire/Wheel Combination. Requires New Wheel Alignment. > > > > > > > > E) Increase Suspension Bushing Durometer. > > > > > > > > F) Revise Power Steering To Give More Feedback > > Sensitivity > > > > > > > > G) Change Shift Linkage To Shorten Throw & Give A > > Tighter > > > > Feel > > > > > on > > > > > > > > 1984 & 1985 > > > > > > > > cars as well 5-Speed Manual 1986 cars. > > > > > > > > H) Tires: Upgraded To P225x50:15" From P225x60:15" Hi > > > > > > Performance To > > > > > > > > Maximize > > > > > > > > Handling & Ride Quality & Enhance Lowered Effect Of > > Vehicle > > > > > B.F. > > > > > > > > Goodrich > > > > > > > > "Comp T/A" > > > > > > > > I) Replace Valve Springs & Rocker Arms To Increase > > Usable > > > > Rev. > > > > > > Limit > > > > > > > > to 7,000 R.P.M. > > > > > > > > J) B-303 Ford MotorSport Hi-Po Cam > > > > > > > > > > > > > > > > Radios > > > > > > > > The Speakers in the front were stock Ford > > > > > > > > The 2 in the hatch were Kenwood. > > > > > > > > They were housed in a rectangle flat black housing with > > the > > > > > name > > > > > > > > KENWOOD stamped > > > > > > > > in the top part of the framework. > > > > > > > > The stereo in the 1984 & 1985 was by Kenwood. > > > > > > > > > > > > > > > > Ground Effects > > > > > > > > You do not need a fog light bar. I would think the > > > > directions > > > > > > would > > > > > > > > point out that > > > > > > > > you need to remove and not reuse a stock fog light bar > > in > > > > > order > > > > > > to > > > > > > > > install the > > > > > > > > airdam. My '85 just had the screws going into some nut- > > > serts > > > > > into > > > > > > > > the urethane. > > > > > > > > > > > > > > > > Front Nose was originally a GS > > > > > > > > > > > > > > > > Rear End > > > > > > > > 3.08:1 Axle Upgrade over 2.73:1 > > > > > > > > > > > > > > > > "Light Group" which was an > > > > > > > > option (order code 934) on the Capri in 1984. > > > > > > > > The "Light Group" includes: > > > > > > > > Third-door courtesy light switch > > > > > > > > Ashtray light (front) > > > > > > > > Glove box light > > > > > > > > Dual-beam dome lamp > > > > > > > > Engine compartment light > > > > > > > > Headlamps-on warning buzzer > > > > > > > > Locking fuel filler door w/remote release > > > > > > > > > > > > > > > > In 1985 the "Light Group" became standard equipment and > > > this > > > > > > carried > > > > > > > > through > > > > > > > > to 1986 as well. > > > > > > > > > > > > > > > > Light Covers > > > > > > > > They were made by a vacuum > > > > > > > > formed machine, from clear lexan plastic. They have 2 > > holes > > > > on > > > > > > top > > > > > > > > that small screws go thru, and down into the plastic > > frame > > > > of > > > > > the > > > > > > > > headlights. On the bottom of them is supposed to be two > > > tabs > > > > of > > > > > > > > velcro that "hook up" to two receiving tabs of oppisite > > > > velcro, > > > > > > > > stuck > > > > > > > > to the top of the bumper cover, but out of sight as > they > > > are > > > > > > under > > > > > > > > the headlamps. If properly installed, they do not leak. > > The > > > > > > > > taillampcovers, on the other hand, do occassionaly leak > > > > > moisture. > > > > > > > > NEVER remove the taillight covers to clean! Changes of > > > > > breaking > > > > > > them > > > > > > > > in the re-install are like 85% ! > > > > > > > > > > > > > > > > Wheels > > > > > > > > 225/60 15" wheels and 25.63 total height top to bottom > > with > > > > > tire. > > > > > > > > <==Help to calc speedo gear. > > > > > > > > 225/50 15" wheels and 23.90 <===These are the correct > > tires. > > > > > > > > > > > > > > > > -Mike > > > > > > > > > > > > > > > >
--- In ascmclaren@yahoogroups.com, "Sandy Block" > > > > > > <cigarsandy@c...> > > > > > > > > wrote: > > > > > > > > > Oh, Also....... > > > > > > > > > > > > > > > > > > Springs were designed by McLaren, and were purpose > > built > > > > to > > > > > > spec. > > > > > > > > > Shocks were by Carerra in Georgia. 50/50 Shocks, the > > > OEMs > > > > > were > > > > > > > > > either WHITE or GOLD exterior casing. They are still > > > > > > available & > > > > > > > > I > > > > > > > > > have the part numbers if anyone needs them. > > > > > > > > > Air Horn by Fila ('Ya the sportswear Mfg'r.) > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
--- In ascmclaren@yahoogroups.com, Tom G > > > > <speedracer815@y...> > > > > > > > > wrote: > > > > > > > > > > > > > > > > > > > > I'm curious about the alterations made to the > > coupes. > > > > I've > > > > > > seen > > > > > > > > > ASC's sales "brochure" and it really doesn't say > > anything > > > > > about > > > > > > > > > performance modifications. > > > > > > > > > > I understand they were DSO'd with the B303 cam. Any > > > > other > > > > > > engine > > > > > > > > > changes? > > > > > > > > > > I also know springs and shocks were different, but > > does > > > > > > anyone > > > > > > > > know > > > > > > > > > the actual spring rates? > > > > > > > > > > As an aside, I'm constantly amazed at the depth of > > > > Sandy's > > > > > > > > > knowledge. Sandy, were you an ASC employee during > that > > > > > period? > > > > > > > > > > Thanks, > > > > > > > > > > Tom > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > > > > > > > > > > > > > > > > > Tax Center - File online, calculators, > forms, > > > and > > > > > more > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
