4659    <<    Message Index    >>    4661
Number: 4660
Date: Wed Mar 10, 2004  10:59 am
Subject: [ASC McLaren ] Re: Interesting figures
Yes, it would be nice if we could get some owners to post more of
their buck tags, door tags and any legible build sheets.
My door tag as everyone probably has seen before is:
http://www.ascmclarencoupe.com/History/MasiBefore/door_tag.jpg
My buck tag is here but I don't have the info on it:
http://www.ascmclarencoupe.com/ascParts/asc_BodyBuckTag.jpg
Its in front of the radiator attached to the cross bar.
> Again, the door tag DSO is different than the internal DSO code.
> The door tag DSO is for the District Sales office. This 2 digit
> code merely shows what district the car is/was intended for. For
> cars that were special orders there is an additional 4 digits that
> are undecipherible without internal paperwork.
> D32 is a code Ford used internally at the plant to identify a
> McLaren build.
> IF everybody would offer up their door tag info we could try to
> narrow down what codes are common for these cars and use those
also
> as identifiers. For instance, maybe all McLaren Capri coupes had
> the same DSO or maybe they all used the same spring codes which is
> coded with the transmission on the tag or maybe they all have the
> same Accesory Reserve Load codes that is printed above the DSO on
> the door tag. This could be done for the Coupes, Capri verts and
> the Mustangs also. There is nothing except the VIN on this tag to
> identify the car so a picture or two of the tag, with only the
last
> 6 digits of the vin blocked out if you so choose, would be great.
> If Sandy wants to handle the load of pics or if Negusm wants to
> fine, or I can too. A few examples of the tags:
> http://www.sspmustang.org/technical/doortags.htm
> Tom S.
--- In ascmclaren@yahoogroups.com, Peter Shear <tfs2121@y...>
> > what about the door tag would it say anything about
> > the D32 build code or something?
> > ~Peter
> > __________________________________
> > > Search - Find what you're looking for faster
> > http://search.yahoo.com
4666 Re: Interesting figures Sandy Block cigarsandy Wed  3/10/2004
4675 Re: Interesting figures negusm negusm Wed  3/10/2004
4679 Re: Interesting figures negusm negusm Thu  3/11/2004
