5040    <<    Message Index    >>    5042
Number: 5041
Date: Mon May 17, 2004  4:52 pm
Subject: Re: [ASC McLaren ] top not working...
it real simple to test the switch. pull it out, on the back there
are 3 wires--1 hot lead, and 2 others one wire releases the top and
the other operates the pull down motor.just pull off the outside
wires one at a time and touch them to the center wire. again one
should pop the release, and the other will pull down the top. if
the pull down wont work this way then you know its the motor, if it
does work then its the switch. one has nothing to do with the
other, the release mechanism is in the tonnou and the pull down
motor is in the trunk. also note that these 2 items run off a self
grounding system(no wire), so you might also check to make sure
there is no build up on the contact points.
jdawg
p.s. if you need pics just ask
--- In ascmclaren@yahoogroups.com, "Dan the Man" <damntheman23@y...>
> ok you think it would be the switch and not the top motor?
because
> when i first bush the switch up the hard cover that holds the top
> actually pops up and after that the motor is supposed to spin the
> screw up and bring the back of the convertible top up so it can be
> stowed away and its this part thats not working...same difference
if
> i close the lid and press down on the switch to have the top
screwed
> back into the car...that doesnt work either...
--- In ascmclaren@yahoogroups.com, Troy Allan Hobbs
> <tallanhobbs@y...> wrote:
> > sounds like your switch is going bad, I had the same issue with
my
> 87 recently, I removed the switch and cleaned up the contacts. It
> was a temporary repair, but got me thru til I got the new switch.
> > Troy
> > Dan the Man <damntheman23@y...> wrote:
> > ok i have an 89 mclaren and the top has stopped working...i can
> > click the button and the back will release and pop up but the
> motor
> > wont spin the screw up anymore...is this a definate sign of a
bad
> > motor?? it wont close the top all the way either...the top is
> > closed but not screwed down all the way....any help would be
> > appreciated and thanks for letting me be a member of this great
> > group...
> > daniel
> Groups Links
> > To visit your group on the web, go to:
> > http://groups.yahoo.com/group/ascmclaren/
> > > > SBC Yahoo! - Internet access at a great low price.
5042 Re: top not working... Dan the Man damntheman23 Mon  5/17/2004
5046 Re: top not working... ecstacycustomz ecstacycustomz Wed  5/19/2004
5072 Re: top not working... Dan the Man damntheman23 Sun  5/30/2004
5082 Re: top not working... Dan the Man damntheman23 Tue  6/1/2004
5083 Re: top not working... hanksgt hanksgt Wed  6/2/2004
5084 Re: top not working... ecstacycustomz ecstacycustomz Wed  6/2/2004
