4025    <<    Message Index    >>    4027
Number: 4026
Date: Sat Nov 29, 2003  12:12 am
Subject: Re: [ASC McLaren ] Re: 85 Coupe Questions
Yep the car I was speaking of is a coupe. Something else to tell you. The
B303 was Motorsports first roller cam offering. If you notice the B303 was
not because the camshaft never got an EO#. In other words it was not legal
to sell it on any productions vehicle that was ever to see the public
highways. Sandy's description of it should tell folks why.
The E303 was emissions exempt and could have been widely advertized by ASC
had it been available in 1985. It was not, nor was the F303
My .02
John (3 asc's)
Sent: Friday, November 28, 2003 8:30 PM
Subject: [ASC McLaren ] Re: 85 Coupe QuestionsThe car's a COUPE, correct???
Okay, the axle ratio thing was an oversight! ascMcLaren did not
think to check out the FoMoCo installed gearing, until mid-production
build of '85. The 2.73:1 was Std. in the GT with the 3.08:1 as a no-
charge option. The 3.08:1 shoulda been included with the D32 build,
so that ALL cars got it, but it wasn't. This was corrected for
the '86 build. Furthermore, SOME (I do not know what mandated it!!)
but SOME '86's had the 3.73:1 ratio, as does mine. Perhaps,
again....a No Charge Option ????
However, the 3.73:1 was NOT (repeat...NOT) available on an '86 Coupe
with the 5-Speed Manual......only with the Automatic Transmission. 5-
Speeds got the 3.23:1. Nobody got the 2.73:1 and 5-speeds got the
3.08:1. While most automatics got the 3.23:1. Confused yet?
Coupes...no 'verts got the B-303. I never heard of an E-303, but
these cars were so confused, nothing surprises me any longer!
You can tell if your car has 303 as if it does, it will be lumpy,
lumpy, lumpy at red lights, and when cold ! It will also sometimes
stall about 3 minutes into "Warm-Up" on a cold AM.
--- In ascmclaren@yahoogroups.com, "capri_16t" <capri_50@m...> wrote:
> Good to know Sandy. Thank you. I just thought ALL came with 3.08s.
> Didn't realize it was an option. My 88 ASC has 3.08's, but didn't
> realize it was standard at that time and not before. Everyday I
> find something a little different on the 85s. My 85 also came with
> an 85mph speedo. I know I read somewhere that most were suppose to
> come with a b-303 cam, but I don't seem to hear the typcial
duration
> sound that i am use to hearing when a regular mustang changes their
> stock grind to a B-303. My other 86 regular capri 5.0 with an E-
303
> sounds a lot more impressive than whatever this cam is. Is it
> possible that mine is a regular stock 85 cam or I am expecting to
> hear something out of a B-303 that really isn't there.....???? It
> also amazes me that Ford would have put a B-303 cam in their since
> the FORD intake cuts off breathing WAY before their own B-303 likes
> to operate and a 2.73 gear isn't hardly enough for a B-303.... But
> I have seen FORD do a lot more crazy things than that.... Give me
> some more info SANDY.... :)
> Jason
> > 1985's came with 2.73:1. The higher ratio was then a no-charge
> > option, and became standard in the 1986's. (We're talkin' coupes
> > here).
> > S A N D Y
> > > Have an interesting question. I have an 85 Blue/orange capri.
> > Door
> > > sticker denotes axle code is 'M'. I thought 'M' is for 2.73's
> > > and 'Z' was for 3.08's. Did the 3.08's not get installed in
> > > rear until later (before the decal was made) or is this one of
> > those
> > > MANY freak mistakes which I happen to have by FORD and/or
> Mclaren.
> > > Jason
> > > > Sandy's Post #356 kind of describes it. There were no
> documented
> > > > options but it seems there were some undocumented ones on the
> > last
> > > > of the '85s.
> > > > -Mike
> > > > > Yeah, I pulled that out from an old posting. I think Sandy
> > > > > clarified that actually some of the later 85's had some
> options
> > > > > added.
> > > > > -Mike
--- In ascmclaren@yahoogroups.com, John Gemelli
> <jgemelli@o...>
> > > > > wrote:
> > > > > > Maybe I misunderstand your chart but I think it's wrong
on
> > > > > 85's as my
> > > > > > Midnight blue coupe has
> > > > > > Pop up sunroof, Power locks and a Remote hatch release in
> > > > > glovebox.
> > > > > > John
> > > > > > From: "negusm" <negusm@y...>
> > > > > > Sent: Thursday, April 10, 2003 9:56 PM
> > > > > > > Well the following I gleaned from all the postings as I
> went
> > > > > > > through...
> > > > > > > Most of it is from sandy and I think it is fairly
> > accurate.
> > > It
> > > > > > > hasn't been cleaned up and may be somewhat
jumbled...but
> > > here
> > > > it
> > > > > > > is...correct anything if it is wrong...
> > > > > > > Coupe information:
> > > > > > > Mercury Capri Coupe GS, tagged with an ASC Mclaren body
> tag
> > > > and a
> > > > > > > Ford code of D32 to
> > > > > > > denote special order.
> > > > > > > Standard Equipment:
> > > > > > > These items were Extra in the Mustang GT, but Standard
> in
> > > ALL
> > > > > Capri
> > > > > > > RS (GS?) 5.0L cars, and therefore also in all
> asc/McLaren
> > > > Coupes,
> > > > > > > from the Dearborn Assembly Plant.
> > > > > > > 1. Power Windows
> > > > > > > 2. Light Group
> > > > > > > 3. Electric Rr. Defroster
> > > > > > > Items standard in the Mustang GT and Capri:
> > > > > > > 1. Tinted Glass
> > > > > > > 2. Tilt Steering Wheel
> > > > > > > Options (From Ford) Installed ON LINE at Dearborn on
OUR
> > > > COUPES,
> > > > > > > were:
> > > > > > > 1985
> > > > > > > NONE
> > > > > > > 1986
> > > > > > > Power Door Locks
> > > > > > > Remote Hatch Release
> > > > > > > Air Conditioning (Standard in 1985)
> > > > > > > Speed Control
> > > > > > > Pop-Up Sun Roof
> > > > > > > T-Roof
> > > > > > > All, except the Air Conditioning which was standard in
> 1985
> > > > > > > (optional in 1986) were NOT available on 1985s.
However,
> > > very
> > > > > near
> > > > > > > the end of production of the 1985's asc/McLaren
> > > added "Oxford
> > > > > White"
> > > > > > > as an alternative color choice to the "Midnight Navy-
> Blue
> > > > > Metallic",
> > > > > > > and at that point, and only on the Oxford White cars,
> they
> > > > > allowed
> > > > > > > the option of Power Door Locks/Remote Hatch release,
> > > Speed
> > > > > > > Control.
> > > > > > > NO 1985s had the Pop-Up Sun Roof, nor the T-Roof, nor
> > > Automatic
> > > > > > > Transmission. 1985s in Oxford White with Pwr. Locks &
> > Speed
> > > > > Control
> > > > > > > are EXTREMELY rare, and I have only 2 on the asc/McLaren
> > > > > > > International Registry, after keeping the Registry now
> for
> > > 16
> > > > > years!
> > > > > > > Of the 1986's, just nine (9) were equipped with the
> > Automatic
> > > > > > > Transmission, and the Pop-Up Sun Roof was on around 20
> > cars,
> > > > > while
> > > > > > > the T-Roof was on around 30 cars. Power Locks were on
> > around
> > > 55
> > > > > > > cars. I have never found an '86 withOUT A/Cond. The
> rarest
> > > > combo
> > > > > > > would have been an '86 in Platinum Silver Metallic with
> > > Raven
> > > > > Black
> > > > > > > decals/logos/stripes, with a T-Roof, Pwr. Locks,
> Automatic
> > > > Trans.
> > > > > > > However, no such car was built!
> > > > > > > Engine Oddities in 1985:
> > > > > > > Odd Sized Piston Rings...Normal ones are TRW Metric Some
> > > > > > > Ford Mustang 1.5mm.-1.5mm-4mm oil ring
> > > > > > > Mercury Capri 1/16-1/16-156mm oil ring
> > > > > > > Some parts scribed with a P for PROTOTYPE by hand
(Valve
> > > > Guides,
> > > > > > > Springs, etc).
> > > > > > > Herewith are the actual alterations done to the MOTOR,
> > > either
> > > > by
> > > > > > > Ford (F)
> > > > > > > or by asc/McLaren (AM)
> > > > > > > A) Upgrade Exhaust Header to Stainless Steel Internal
> > > Mandrel
> > > > > Bent
> > > > > > > Incorporate Exhaust Port Liners Tuned With Lower
> > Restriction
> > > > > Exhaust.
> > > > > > > B) Tuned Muffler To Reduce Back Pressure & Enhance
> Exhaust
> > > > Tone.
> > > > > > > C) Replace Damper Units & Springs To Achieve Better
> > > Cornering
> > > > & A
> > > > > > > Softer
> > > > > > > Ride than The TRX System.
> > > > > > > D) Modify Camber Of Vehicle Front & Rear To Maximize
> > > > Performance
> > > > > Of
> > > > > > > Upgraded
> > > > > > > Tire/Wheel Combination. Requires New Wheel Alignment.
> > > > > > > E) Increase Suspension Bushing Durometer.
> > > > > > > F) Revise Power Steering To Give More Feedback
> Sensitivity
> > > > > > > G) Change Shift Linkage To Shorten Throw & Give A
> Tighter
> > > Feel
> > > > on
> > > > > > > 1984 & 1985
> > > > > > > cars as well 5-Speed Manual 1986 cars.
> > > > > > > H) Tires: Upgraded To P225x50:15" From P225x60:15" Hi
> > > > > Performance To
> > > > > > > Maximize
> > > > > > > Handling & Ride Quality & Enhance Lowered Effect Of
> Vehicle
> > > > B.F.
> > > > > > > Goodrich
> > > > > > > "Comp T/A"
> > > > > > > I) Replace Valve Springs & Rocker Arms To Increase
> Usable
> > > Rev.
> > > > > Limit
> > > > > > > to 7,000 R.P.M.
> > > > > > > J) B-303 Ford MotorSport Hi-Po Cam
> > > > > > > Radios
> > > > > > > The Speakers in the front were stock Ford
> > > > > > > The 2 in the hatch were Kenwood.
> > > > > > > They were housed in a rectangle flat black housing with
> > > > name
> > > > > > > KENWOOD stamped
> > > > > > > in the top part of the framework.
> > > > > > > The stereo in the 1984 & 1985 was by Kenwood.
> > > > > > > Ground Effects
> > > > > > > You do not need a fog light bar. I would think the
> > > directions
> > > > > would
> > > > > > > point out that
> > > > > > > you need to remove and not reuse a stock fog light bar
> in
> > > > order
> > > > > to
> > > > > > > install the
> > > > > > > airdam. My '85 just had the screws going into some nut-
> > serts
> > > > into
> > > > > > > the urethane.
> > > > > > > Front Nose was originally a GS
> > > > > > > Rear End
> > > > > > > 3.08:1 Axle Upgrade over 2.73:1
> > > > > > > "Light Group" which was an
> > > > > > > option (order code 934) on the Capri in 1984.
> > > > > > > The "Light Group" includes:
> > > > > > > Third-door courtesy light switch
> > > > > > > Ashtray light (front)
> > > > > > > Glove box light
> > > > > > > Dual-beam dome lamp
> > > > > > > Engine compartment light
> > > > > > > Headlamps-on warning buzzer
> > > > > > > Locking fuel filler door w/remote release
> > > > > > > In 1985 the "Light Group" became standard equipment and
> > this
> > > > > carried
> > > > > > > through
> > > > > > > to 1986 as well.
> > > > > > > Light Covers
> > > > > > > They were made by a vacuum
> > > > > > > formed machine, from clear lexan plastic. They have 2
> holes
> > > on
> > > > > top
> > > > > > > that small screws go thru, and down into the plastic
> frame
> > > of
> > > > the
> > > > > > > headlights. On the bottom of them is supposed to be two
> > tabs
> > > of
> > > > > > > velcro that "hook up" to two receiving tabs of oppisite
> > > velcro,
> > > > > > > stuck
> > > > > > > to the top of the bumper cover, but out of sight as
they
> > are
> > > > > under
> > > > > > > the headlamps. If properly installed, they do not leak.
> The
> > > > > > > taillampcovers, on the other hand, do occassionaly leak
> > > > moisture.
> > > > > > > NEVER remove the taillight covers to clean! Changes of
> > > > breaking
> > > > > them
> > > > > > > in the re-install are like 85% !
> > > > > > > Wheels
> > > > > > > 225/60 15" wheels and 25.63 total height top to bottom
> with
> > > > tire.
> > > > > > > <==Help to calc speedo gear.
> > > > > > > 225/50 15" wheels and 23.90 <===These are the correct
> tires.
> > > > > > > -Mike
> > > > > <cigarsandy@c...>
> > > > > > > wrote:
> > > > > > > > Oh, Also.......
> > > > > > > > Springs were designed by McLaren, and were purpose
> built
> > > to
> > > > > spec.
> > > > > > > > Shocks were by Carerra in Georgia. 50/50 Shocks, the
> > OEMs
> > > > were
> > > > > > > > either WHITE or GOLD exterior casing. They are still
> > > > > available &
> > > > > > > I
> > > > > > > > have the part numbers if anyone needs them.
> > > > > > > > Air Horn by Fila ('Ya the sportswear Mfg'r.)
> > > <speedracer815@y...>
> > > > > > > wrote:
> > > > > > > > > I'm curious about the alterations made to the
> coupes.
> > > I've
> > > > > seen
> > > > > > > > ASC's sales "brochure" and it really doesn't say
> anything
> > > > about
> > > > > > > > performance modifications.
> > > > > > > > > I understand they were DSO'd with the B303 cam. Any
> > > other
> > > > > engine
> > > > > > > > changes?
> > > > > > > > > I also know springs and shocks were different, but
> does
> > > > > anyone
> > > > > > > know
> > > > > > > > the actual spring rates?
> > > > > > > > > As an aside, I'm constantly amazed at the depth of
> > > Sandy's
> > > > > > > > knowledge. Sandy, were you an ASC employee during
that
> > > > period?
> > > > > > > > > Thanks,
> > > > > > > > > Tom
> > > > > > > > > > > > > > > > > Tax Center - File online, calculators,
forms,
> > and
> > > > more
4028 Re: 85 Coupe Questions capri_16t capri_16t Sat  11/29/2003
4029 Re: 85 Coupe Questions capri_16t capri_16t Sat  11/29/2003
4215 Exhaust question capri_16t capri_16t Sun  12/28/2003
4216 Re: Exhaust question Brent Abrams ascmclarencoupe Mon  12/29/2003
