0613    <<    Message Index    >>    0615
Number: 0614
Date: Wed Mar 6, 2002  2:42 pm
Subject: Re: 88 McLaren
Hello Anthony !
Some Rumor! No where close to 300HP, they do produce 225 H.P.
They DID "hop-up" the rear end! In 5-Speed cars the standard rear
was 2.73 & they upped it to 3.08. In automatic cars standard was
3.23 & they hopped it up to 3.73.
Regarding exhaust. The cars were the LX model 2-Door Sedan
(Notchback - the one with the back trunk). The V-8 LX used a de-
tuned version of the GT's exhaust system. HOWEVER asc/McLaren Spec
(D32 cars) were built BY Ford at the Dearborn Assembly Line using the
GT exhaust system. (Note that the tips of the exhaust on GTs bend
downward at the rear most tips, and that V-8 LX(s) go straight out.)
If still equipped with OEM you'll see asc/McLaren's pipes turn
downward at the rear bumper.
> Hey Sandy show me your stuff!
> Here it goes:
> 1) I have a 1988 McLaren. I heard a rumor that they produce
300hp!
> First, is this true, and second how can this be true when all they
> added was a Ford B-cam? If they added more I would be very
> interested to hear about it. Did they hop up the computer???
> 2) What gear ratio is the rear 2.73? Same as stock, or is it that
> hopped up to?
> 3) I was thinking of changin the exhaust by adding a 2 1/2" hi-flow
h-
> pipe w/cats, and finish the rest of the exhaust with 2 1/2" and mac
> mufflers. I was wondering if the exhaust is different than an LX
> coupe, and if I change it will it help or hurt performance? I know
> they sometimes calibrate back pressure to the specs of the engine,
so
> I don't want to loose any horsepower, if anything I want to gain!
> I know your the GOD of McLarens, so I appreciate any info/help with
> my questions. Thank you.
> Anthony
> ***bE oRiGiNaL***
633 Re: 88 McLaren asc88mclaren asc88mclaren Sat  3/9/2002   2 KB
635 Re: 88 McLaren cigarsandy cigarsandy Sat  3/9/2002   3 KB
638 Re: 88 McLaren n20capri n20capri Sat  3/9/2002   3 KB
636 Re: 88 McLaren n20capri n20capri Sat  3/9/2002   3 KB
637 Re: 88 McLaren cigarsandy cigarsandy Sat  3/9/2002   4 KB
639 Re: 88 McLaren hanksgt hanksgt Sat  3/9/2002   4 KB
646 Re: 88 McLaren ho660 ho660 Sun  3/10/2002   5 KB
650 Re: 88 McLaren asc88mclaren asc88mclaren Mon  3/11/2002   4 KB
653 Re: 88 McLaren cigarsandy cigarsandy Mon  3/11/2002   5 KB
